2002 DTS Northstar questions
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, 2002 DTS Northstar questions in Cadillac Engine Discussion; Hey everyone,looking at a caddy for my niece.88,000 mile car.seems clean,except it looks like like the belt for what i ...
    Orange Cobra is offline Cadillac Owners Member
    Automobile(s): NONE
    Mar 2013
    41
    1
    Hey everyone,looking at a caddy for my niece.88,000 mile car.seems clean,except it looks like like the belt for what i think is the water pump belt is shredding.my question is has anyone expierenced this and is it a sign of the pump going bad?What other things are these cars notorious for?car is for my niece and i want to know what to look for...thanks everyone,Mike
    Submariner409's Avatar
    Submariner409 is offline If it won't run, stick on fender vents
    Feb 2006
    MD Eastern Shore, Kent Island
    56,590
    Re: 2002 DTS Northstar questions
    It's not the pump, 99% chance. The pump drive system uses a large plastic pulley with metal hub pressed onto an extension of the left bank intake cam. That pulley drives the pump pulley via a 3-rib belt and tensioner arm pulley: THAT tensioner pulley is a sealed ball bearing unit and it WILL eventually dry out and seize. (Ask me/us how I/we know).
    Simple repair-replacement. The tensioner pulley can be replaced separately from the spring arm. Look in the Cadillac Tech Tips for How-to's and in my albums for pictures and diagrams of the parts. The Community tab, Albums, the two with the red Seville on the covers.
    bigtone's Avatar
    bigtone is offline Cadillac Owners Enthusiast
    Automobile(s): 2010 DTS, 2006 DTS, 2001 Deville,
    Jun 2003
    551
    Quote Originally Posted by Orange Cobra View Post
    2002 is still a potential headgasket year. Although not a 100% guarantee, I would do a block test first. Also, although the DTS version of the Deville is desirable, any suspension issues such as worn struts or shocks can be much more expensive than a base or DHS edition. The other more common failures are:
    Bad intake plenum (I've owned 4 Devilles from 01-05, and all 4 had bad plenums).
    mode actuator (2 out of 4)
    AC compressor (3 out of 4.
    Torque converter lock up solenoid (2 out of 4)
    Not to discourage you, I love these cars, but now that they are 10 years old, repairs can add up if you are not a DIYer.[COLOR="Silver"]
