P0719how much coukd this code cost me
Results 1 to 5 of 5
Northstar Engines and System Technical Discussion Discussion, P0719how much coukd this code cost me in Cadillac Engine Discussion; I have 2000 sts with a service suspension message on dash. Ran codes got rssc0625 and pcm p0719 ....
    J2000ssts is offline Cadillac Owners Member
    Automobile(s): 2000 STS, 135,000 miles
    Mar 2013
    9
    69
    82,272
    Re: P0719how much coukd this code cost me
    Codes are meaningless without their definitions. No one has them memorized. Help us help you and use the OBDII link in the DTC Sticky at the top of the forum to get the code definitions.
    Mar 2013
    9
    Po719 tcc brake switch low input. And also rssc0625 rear left position sensor regulates the ride heigth.
    Manic Mechanic is offline Cadillac Owners Fanatic
    Automobile(s): 2001 DeVille
    Sep 2011
    Magnolia, TX (NW of Houston)
    47
    411
    Those two codes coukd cost you up to $600. Give or take.
    Vernon
    Mar 2013
    9
    Thanks sounds rite
  8. Remove Advertisements
