1998 Deville Northstar - ready to get my hands dirty - Page 3
Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 31 to 45 of 47
Like Tree9Likes
Northstar Engines and System Technical Discussion Discussion, 1998 Deville Northstar - ready to get my hands dirty in Cadillac Engine Discussion; You mentioned that you were going to drop the cradle out the bottom. Bill Buttermore did the same with his ...
  1. #31
    daveyhouse is offline Cadillac Owners Fanatic
    Automobile(s): 98 deville D'Elegance 86 Fiero 2m4 / 86 Fiero GT W/SBC
    Jun 2012
    York, Pa
    234
    Re: 1998 Deville Northstar - ready to get my hands dirty
    You mentioned that you were going to drop the cradle out the bottom. Bill Buttermore did the same with his and is well documented here http://www.cadillacforums.com/forums...case-leak.html
  2. #32
    KidCavanna is offline Cadillac Owners Member
    Automobile(s): 1998 Deville
    Feb 2013
    16
    Finally the stars and planets are aligned...and thanks to Daveyhouse all is in order. I am going to try to do an out and in....in one day. Last chance for input for things to check and or replace. Please don't hold back....
  3. #33
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,998
    Good luck. This thread was enough to get up on my feet and go continue working on my Deville! No night is too late for me.
  5. #34
    Jun 2012
    York, Pa
    234
    If you only got the headgasket kit you will probably need a timing cover gasket and a front main seal. If you need any tools, torque wrenches, etc. Let me know. The head bolts take a 10mm hex bit, and there are 3 small bolts at the front of the head take a 10mm socket. Don't forget to tape off the decks real good before drilling.
  6. #35
    Feb 2013
    16
    Well today was the day. Now at the point of no return. The motor is dropped out the bottom with only one wire connecting it to the car. Have to take out the glove box to get to the harness. Not too many snags only broke the nipple off of the coolant reserve tank.
    CadillacLuke24 likes this.
  7. #36
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,919
    Your statement "out and in in one day" ............ You might want to plan on AT LEAST 10 days, intense work. Do the studs perfectly and seal every block hole or you'll pay dearly in a ruined engine: aluminum chips are going to fly everywhere.
    If you go into the lower end, be ready to replace all the bearings and the connecting rod end cap bolts. There is a new, special technique for sealing the halfcase and oil pan flanges - it involves the use of UltraGray RTV sealant.
    You'll NEED a GM service manual for reference to all the special procedures and torque values needed - Do you speak oil pump drive sleeve and harmonic balancer torque settings - so you don't lose oil pressure ??? How about timing those 3 chains and 4 cams ??
    New coolant surge tank from Amazon - about $58, shipped.
  8. #37
    Feb 2013
    16
    Out and in in a day was more like a dream. Did get it out in a day tho. Got the GM manuals. Plus I've got Daveyhouse my knight in shining armor to take all of my million calls and questions. Just doing the head gaskets and whatever I come across that needs replacing. All hoses and some vacuum lines.
  9. #38
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,998
    Good luck! I remember that wire, instead of messing with the glove box I just decided to undo it from the engine side when it's jacked up enough.
  10. #39
    04GrandAmGT's Avatar
    04GrandAmGT is offline Cadillac Owners Fanatic
    Automobile(s): 2001 DTS, 04 Grand Am GT,07 Cobalt(Dont Judge,My fuel Saver)
    Oct 2012
    Manitoba, Canada
    376
    Good luck with the Build from us here at Northstar Performance. if you have any questions please feel free to reply to this post.
  11. #40
    Feb 2006
    55,919
    Nice to see a class act. ^^^
    04GrandAmGT likes this.
  12. #41
    CadillacLuke24's Avatar
    CadillacLuke24 is offline Cadillac Owners Master
    Automobile(s): Alexandra - 96 SDV --- Clyde - 15 Silverado
    Jul 2010
    Wyoming
    26
    5,740
    Quote Originally Posted by 04GrandAmGT View Post
    Thanks for checking in Everett and Jake Good customer service.
  13. #42
    Feb 2013
    16
    Engine on ground. Wire still connected. I'm 1500 miles away. Hopefully the Cadillac gods will come down and bless me with a completed N* job on my return.
  14. #43
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,998
    By the time when you finish, you definitely will be tired, but a properly working Northstar is such a reward. That feeling when you first start it and it fires up.
  15. #44
    Oct 2012
    Manitoba, Canada
    376
    may i mention one thing, if you want the longest lasting seal out there, we use ACDelco Sealant from GM, it is a half decent price and it works amazing! and also if you are looking for the oil manifold plate we got them for $85 + shipping
  16. #45
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
    You did not mention splitting block to reseal so I assume you do not have any major block oil seepage? Pulling motor and than heads is hard enough.
  17. Remove Advertisements
