Issues with code P 0411 - 2006 DTS
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 24
Like Tree1Likes
Northstar Engines and System Technical Discussion Discussion, Issues with code P 0411 - 2006 DTS in Cadillac Engine Discussion; I do not know if you guys have the issued that I have my dts has over 200k and got ...
    grullon10's Avatar
    grullon10 is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 cadillac dts
    Dec 2012
    46
    553
    I do not know if you guys have the issued that I have my dts has over 200k and got the code p0411 six mth ago. Change the smog pump the check valve the relay check for leaks.did not any no where. I have spend more than $300 trying to find the fix. Any one has a ideal what it could be. Ps I have a friend with the same problem he also did the same thing I did to try to fix it with no lk.
    68
    81,916
    Re: issued with code p0411
    Help us help you and always post the code definitions along with the codes. No one has them memorized.
    grullon10's Avatar
    Dec 2012
    46
    553
    P0411 is air injection incorrect flow. I had done everything to fix it.
    68
    81,916
    Re: Issues with code P 0411 - 2006 DTS
    I'm not familiar with the '06 DTS. Does it have 2 check valves like it's predecessors?
    Disregard. Just looked it up and apparently there is only one. I wonder if it somehow is stuck open? If it is, I would expect hose #6 & 9 to be hot.
    grullon10's Avatar
    Dec 2012
    46
    553
    I change the valve the next thing I'm going to do is going to replace both line 6 and 9 . I do not what to keep replacing part that re good. They are not cheap not even on ebay.
    68
    81,916
    I can't see where replacing those hoses will help any.
    grullon10's Avatar
    Dec 2012
    46
    553
    If I am not able to find out what is wrong I'm going to trade in. I'm not getting another cadi.
    Manic Mechanic is offline Cadillac Owners Fanatic
    Automobile(s): 2001 DeVille
    Sep 2011
    Magnolia, TX (NW of Houston)
    46
    413
    Get a Lexus, it's going to cost a customer friend $2,300 in parts and 3+ hours labor to replace his AIR pump and valve block under the intake manifold of his wife's V8 luxury SUV at 85K. Any V8 Toyota uses the same set up and they go through so many all dealers keep them on the shelf. Be careful what you ask for.
    Grullon, I have to ask since you didn't state it, is your AIR pump even working at over 200K? As a professional who works on these a lot I seriously doubt it. If the pump, #10 in the diagram above, located in the LH front fender behind the headlamp and ahead of the tire, doesn't spool up and hum for a a minute or so on every cold start it's probably worn out and non-functional. Even if it does chances are that it is no longer sealed from plenum to check valve. Mine was broken at 130K and I picked up another at Pick-A-Part self serve auto salvage for $15. That's one thing Cadillac has going for it, cheap accessible parts.
    If it is and you actually have done everything to fix and diag this problem then I would suspect the AIR injection manifold and or ports in the exhaust side of the cylinder heads are carbon locked. The pump, hoses, and valves can supply air to the head but it carbon has built up to the point it blocks or restricts the passages in the head it won't effect the O2 sensor reading due to no flow. On this engine and chassis, it is a major repair. The manifolds would have to come off and the carbon be physically removed. You could try to push compressed air in down stream of the check valve and see if it meets resistance to check. If it's clogged up and has 200K on it then I might retire it myself.
    Vernon
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
    Dayum! 200k on an 06? Get rid of that pig.
    grullon10's Avatar
    Dec 2012
    46
    553
    I already push conpressed air though the valve port and it did not work . I tested the system with the gm scanner we turn the pump on and there was a change on o2 reading when it was on. And one more thing I buy american. If I don't buy another caddy I'm getting a lincoln.
    Aug 2007
    mpls mn
    2,528
    well, any other car with lower miles will probably have fewer issues. are you going to buy a new lincoln? i would like a new linc. heck, i would like any NEW car. but i dont really want to pay for a NEW car.
    68
    81,916
    Quote Originally Posted by grullon10 View Post
    grullon10's Avatar
    Dec 2012
    46
    553
    No I'm in the livery service in new york that's why my car has that many miles. In this type of jobs I have learn that buy a new car it not woth it . On any car that put livery plate on lose it value a lot faster than any other car.
  16. #14
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,881
    You would be far better off with a Ford Panther vehicle - Crown Vic or Town Car.
  17. #15
    grullon10's Avatar
    Dec 2012
    46
    553
    They don't make them any more. I had 4 town cars before I got my dts. Now I understand why they use those type of cars.
  18. Remove Advertisements
