To fix the Blown Head Gasket, how hard is it if DIY?
Results 1 to 5 of 5
Northstar Engines and System Technical Discussion Discussion, To fix the Blown Head Gasket, how hard is it if DIY? in Cadillac Engine Discussion; how hard is it if DIY? I don't have much experience but I'd like to learn. I changed timing belt ...
    31415926's Avatar
    31415926 is offline Cadillac Owners Fanatic
    Automobile(s): 1998 Cadillac Deville Sedan
    Mar 2004
    San Diego
    107
    how hard is it if DIY? I don't have much experience but I'd like to learn. I changed timing belt for my old small car and that was the hardest one I ever did.
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,848
    Look at my started threads i posted a guide on removing the engine. Youre gonna be way in over your head...when it comes to the Northstar Head Gasket repair..
    69
    82,262
    Re: To fix the Blown Head Gasket, how hard is it if DIY?
    Drop the drivetrain out the bottom. Pull the heads. Drill and retap the bolt holes. Install inserts or studs. Revers the procedure. Easy eh! Check the Tech Tips section. There are several tutorials in there.
    SC2150's Avatar
    SC2150 is offline Cadillac Owners Connoisseur
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    60
    1,847
    LOL Ranger! Not so easy for the DIY'r is it. And the thread cert kit is a must. Even changing the water pump on these is a major headache for the avg handy man.
    69
    82,262
    Yes, inserts are a must once the heads are removed.
    W/P is actually pretty easy, but you DO need the W/P socket.
  8. Remove Advertisements
