Oil pressure problem
Results 1 to 9 of 9
Northstar Engines and System Technical Discussion Discussion, Oil pressure problem in Cadillac Engine Discussion; My 96 deville is giving my the damn flashing light and stop engine warning every so often sometimes days and ...
    unruley247 is offline Cadillac Owners Fanatic
    Automobile(s): 02 300m special,04 Intrepid, 07 Z06 and a 05 Yukon
    104
    My 96 deville is giving my the damn flashing light and stop engine warning every so often sometimes days and week apart I have had the oil pump and oil pressure senor change. On the day when warning shows up rpm are around 700 when idle. I need help!!!!!!!!!! I hope I don't need Bearings Might junk if I do Because I Have 200000 miles on motor
    sts96 is offline Cadillac Owners Fanatic
    May 2004
    333
    Re: Oil pressure problem
    Perhaps its time to switch to high milage engine oil or the next weight . Imagine at only 200k. lol sts96
    104
    Do you think 10-40 can do the trick
    May 2004
    333
    I think loss of oil pressure at idle will do more damage than 10-40 ever would. lol sts96
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,241
    I usually troubleshoot oil pressure problems by temporarily installing a known good gauge in parallel with an idiot light sensor and finding out what the problem really is. Then you can tell if it is a worn out motor, bad relief valve, or just a sender problem.
    BeelzeBob's Avatar
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    Try one of the heavy duty 15W40 oils such as Delvac or Delo or Rotella. The extra viscosity may help prevent the oil pressure warning light from coming on.
    Was the replacement oil pressure switch an OEM part or a generic part from the autoparts store?? If it was a generic part you might try the OEM part as the set point for the oil pressure warning is specific to the Northstar.
    104
    I don't know where switch was purchased but believe from car quest maybe i will get one from gm
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,241
    As a last ditch measure there are oil pressure switches for trucks that are adjustable by exchanging shims under a spring.
    BeelzeBob's Avatar
    Dec 2002
    52
    9,577
    Quote Originally Posted by unruley247
    If it was anything other than a Cadillac Northstar specific oil pressure switch it will cause problems like you describe. Get the OEM switch.
  12. Remove Advertisements
