STS High Idle
Results 1 to 14 of 14
Northstar Engines and System Technical Discussion Discussion, STS High Idle in Cadillac Engine Discussion; I have a 1993 STS that has recently been idling high, over 1200 RPM. Checked codes and came up with ...
    BSexton is offline Cadillac Owners Member
    Dec 2004
    62
    14
    STS High Idle
    I have a 1993 STS that has recently been idling high, over 1200 RPM. Checked codes and came up with P030 which i understand to be ISC RPm out of range.Can someone tell me how to correct the high idle?
    Thanks, Bill
    69
    82,188
    Re: STS High Idle
    Search the archives. I am sure I have seen bbob explain how to properly adjust it. If that doesn't work, likely it is failing and needs replacing. I am assuming you know that ISC is the idle speed control motor or did the '93 use the idle speed control valve? If it is the valve, it will be located on the forward side of the T/B and may just be sticking and allowing too much bypass air causing a high idle.
    peteski is offline Cadillac Owners Enthusiast
    Automobile(s): 85 Eldo Biarritz
    Dec 2003
    Northeast USA
    808
    Re: STS High Idle
    You might also want to check for vacuum leaks (at the intake manifold). My 93 was idling a litttle high (once it also set same error code as yours). What I found was a disconnected vacuum hose on the top of the throttle body (if that is what it is called). There is a rubber or plasic piece with 3 openings and 3 vacuum lines attached. One of mine was disconnected. That was allowing extra air into the intake manifold.
    I hooked it back up and it is now idling around 700RPMs.
    Peteski
    Spyder's Avatar
    Spyder is offline Cadillac Owners Master
    Automobile(s): None now...1972 Challenger=my pride and joy.
    May 2004
    Sonoma Co, CA
    34
    5,688
    Re: STS High Idle
    My 94 STS just got a new ISC motor...was clicking and buzzing and making noises for ten or fifteen seconds at startup and shutdown, and towards the end started idling at around 1100, which caused it to run hot, around 230 in town with it being 45 degrees out...put the new one in and it fixed everything. Check the vacuum lines first though, as the ISC costs about $95 from napa...it is quick and easy to change out by yourself though.
    Dec 2004
    62
    14
    Re: STS High Idle
    I have also heard the 10 seconds of clicking after I shut the engine off. Is this an indication of a bad ISC motor? Also is there a website that would show pictures from a manual that would show where and what the ISC motor would look like on a 1993 STS?
    Thanks Bill
    69
    82,188
    Re: STS High Idle
    Yes, I think that is a sign of a failing ISC motor. Check the last page of this thread. There is a picture there. Also some good info in the thread.
    http://caddyinfo.ipbhost.com/index.p...opic=2969&st=0
    cart69's Avatar
    cart69 is offline Cadillac Owners Fanatic
    Automobile(s): 96STS engine only!! only thing left from my 96 after divorce
    Dec 2004
    Illinois
    36
    150
    Re: STS High Idle
    i have the same code for isc out of range and my idle is high 1200 or so and just this morning i heard a weird clicking noise when i turned the key on, before i cranked the engine to start it, it did not make the noise when i got to work and turned the car off though, bad isc????
    Spyder's Avatar
    May 2004
    Sonoma Co, CA
    34
    5,688
    Re: STS High Idle
    That's what mine was...clicking came first though, idle was fine for a couple of weeks worth of clicking, then it went to around 1200...replaced ISC, high idle and click went away...it still revs to about two grand at startup, which I havn't had time to fix yet, but I need to do some research. Try testing the ISC, outlined somewhere on this forum, or just replace it to fix the clicking andhigh idle.
    cart69's Avatar
    Dec 2004
    Illinois
    36
    150
    Re: STS High Idle
    mine has had the high idle ever since i got the car, but i just noticed the clicking the other day, so its probably been bad the whole time. when i took the intake off my carto clean the egr passages and stuff i put a small bit of high tack gasket sealer over all the o-rings type gaskets so i am pretty sure there inst a vaccum leak in the intake, so i guess napa i will go probably in the next few weeks since i dont have the 100 for it now, what were you saying about the 2000 rpm start mine just starts a little high for a second then goes to its normal idle spot,.
    Spyder's Avatar
    May 2004
    Sonoma Co, CA
    34
    5,688
    Re: STS High Idle
    yea...about half of the time mine will rev up to rwo grand at start, then even out like it should...I havn't figured out what this is yet...I need to get busy with the search on this forum, cause I've read about it before it happened to mine, I just don't remember where it was.
    CAJUN-Z is offline Cadillac Owners Member
    New Orleans, LA.
    61
    16
    Re: STS High Idle
    ...sounds like a vacuum leak....
    you can get a spray bottle of water and spray around manifold and such and you'll get a rough idle if the engines sucks some water...
    works for me...
    blunted is offline Cadillac Owners Enthusiast
    May 2004
    NYC
    585
    Re: STS High Idle
    Interesting.. my car is also running a little hot and when I shut it I've heard clicking. I idle at about 800-900 rpm, I'm not getting any codes though.. bad ISC?
    Spyder's Avatar
    May 2004
    Sonoma Co, CA
    34
    5,688
    Re: STS High Idle
    I never had any codes show up...once in a while I'd get an "rpm out of range -cruise" code, but that was once a week, and would clear itself right away.
  16. #14
    klt
    klt is offline Cadillac Owners Member
    Jul 2004
    42
    Re: STS High Idle
    Hope I'm not adding confusion. If the high idle starts AFTER the engine warms up but not while engine is cold it might be the oxygen sensor. The computer doesn't check the output of the oxygen sensor until the temperature sensor indicates the engine has reached operating temperature. I had a bad oxygen sensor and a bad ISC motor. I got the idle speed back to normal by adjusting the ISC motor plunger but I still get the ISC clicking at engine turn on/off. I tried all of those adjustment procedures. Figured something else was bad that I never found what. Finally decided I could live with a few clicking noises.
  17. Remove Advertisements
