traction control light
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, traction control light in Cadillac Engine Discussion; i have a 96 sts and my traction control light is coming on alot now for no apparent reason. It ...
    scottm is offline Cadillac Owners Member
    Aug 2004
    38
    i have a 96 sts and my traction control light is coming on alot now for no apparent reason. It also feels like the transmission will not use 1st gear to pull out or downshift to when this light is on. I assume the computer keeps it out of 1st to limit wheel spin with the traction control off?
    scott
    69
    82,268
    Re: traction control light
    Your assumption is correct. Enter the onboard diagnostics and pull the codes. That will likely tell you where the problem lies. These cars are very good at self diagnosing. Cadillac, heal thy self.
    Spyder's Avatar
    Spyder is offline Cadillac Owners Master
    Automobile(s): None now...1972 Challenger=my pride and joy.
    May 2004
    Sonoma Co, CA
    34
    5,688
    My traction control light comes on quite a bit as well, but there's definately a known reason for it. };->
