1994 Concours - head gasket replacement ?
Results 1 to 4 of 4
Northstar Engines and System Technical Discussion Discussion, 1994 Concours - head gasket replacement ? in Cadillac Engine Discussion; Originally Posted by bigtone If you do a search, I posted previously how I did HG in the car. I ...
    killzfast is offline Cadillac Owners Member
    Automobile(s): 94 cadillac concours
    Feb 2012
    arkansas
    34
    8
    Quote Originally Posted by bigtone View Post
    If you do a search, I posted previously how I did HG in the car. I only removed the bolts from the timing cover, there is enough room to get in there to release the tensioners without removing the balancer.
    how hard of a job is replacing the front gasket on the northstar I'm needing to change mine?
    ternstes is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS V, 2007 SRX V8, 2005 CTS 3.6L, 2000 STS, 1999 STS
    Nov 2008
    SW Ohio
    36
    393
    Re: timing chain with engine in car
    You might want to start your own thread on the matter, but the first piece of advice I will give you is if you are going to go through the trouble of doing one side properly, you should just do both sides.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,148
    New thread coming soon to this site.....................
    "1994 Concours head gasket replacement"
    bigtone's Avatar
    bigtone is offline Cadillac Owners Enthusiast
    Automobile(s): 2010 DTS, 2006 DTS, 2001 Deville,
    Jun 2003
    567
    Re: 1994 Concours - head gasket replacement ?
    There is tons of info on this forum reguarding h/g failure and replacement. You should take some time and do some reading. Obviously, considering the amount of work involved, you want to make very sure that it is the head gasket that is failed. And if it is, you need to replace both. The block test is the accepted standard for confirming that the h/g is failed, but as I recently experienced myself, it is not always 100% accurate. I know I'll hear some feedback on that statement!
  7. Remove Advertisements
