97 Concours won't start now
Results 1 to 10 of 10
Like Tree1Likes
  • 2 Post By stoveguyy
Northstar Engines and System Technical Discussion Discussion, 97 Concours won't start now in Cadillac Engine Discussion; So my 97 deville finally quit starting... It used to start after seriously 5 min of turning the key (it ...
    bvaughn503's Avatar
    bvaughn503 is offline Cadillac Owners Member
    Jun 2012
    32
    So my 97 deville finally quit starting... It used to start after seriously 5 min of turning the key (it does kick over) itll finally start up slowly this would happen in the morning first start after that it would start alright I've been replacing sensor after sensor an now it won't start at all
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,925
    Re: 97 concours won't start now
    Have you looked for any stored DTC's in your car's built-in code reader/scanner to see if there is a possible lead there ? Something is causing extended cranking, and chances are the problem has set one or more trouble codes.
    Sensors aren't usually the problem - it's fuel, air, spark operation. New plugs, wires, fuel filter ??? Clean ICM and coils ???
    You might also use a fuel pressure test gauge on the fuel rail port to see what Key-ON, cranking, and running fuel pressures are.
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
    Bs. 5 min of cranking? Must be damn good battery.
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,872
    Check your battery bolts, these cars do NOT like the slightest stripping or looseness of them..
    bvaughn503's Avatar
    Jun 2012
    32
    It is the fuel pump finally went out
    Aug 2007
    mpls mn
    2,528
    Cool. Someone actually came back and updated us on what was wrong.
    vincentm's Avatar
    Aug 2010
    Kennewick WA
    38
    4,872
    Running a car constantly on low fuel and shorten the lifespan of any fuel pump. Personally i dont let my baby get below half a tank
    bvaughn503's Avatar
    Jun 2012
    32
    Now I will defenitly be running off the top half. I would like you said run it low all the time than finally it went out I had a mechanic check the fuel pressure like 3 months ago an it was at 30 lbs of pressure than I finally took it in to the shop cause I was sure it was the pump an it was at 10 lbs it would also cause loss of power sometimes so it took awhile for this pump to finally give also it was the original an it had 168zzz miles on it
    weister42 is offline Cadillac Owners Enthusiast
    Automobile(s): 1998 Cadillac Deville Sedan
    Feb 2005
    897
    Re: 97 Concours won't start now
    Doesn't the N* have a feature in which the engine can still start even if the pump is dead?
    Feb 2006
    55,925
    Fuel injection requires quite a bit of pressure to atomize fuel at injector. No pump = no pressure = no start/run.
    I think the early Corvette used mechanical fuel injection, but today's gasoline engines are almost exclusively electric pump-fed types.
    Most diesel engines (commercial) use a mechanical fuel lift pump which feeds a mechanical high pressure injector pump - if you can roll the engine over to some degree it will run.
  13. Remove Advertisements
