Looking for Northstar experts in or around Atlanta, GA
Results 1 to 7 of 7
Like Tree1Likes
  • 2 Post By Eldorado_RED
Northstar Engines and System Technical Discussion Discussion, Looking for Northstar experts in or around Atlanta, GA in Cadillac Engine Discussion; Greetings. I was wondering if anyone is in or near the Atlanta, GA area that can help me out. I ...
    Eldorado_RED is offline Cadillac Owners Member
    May 2004
    Atlanta, GA
    SmileLooking for Northstar experts in or around Atlanta, GA
    Greetings.
    I was wondering if anyone is in or near the Atlanta, GA area that can help me out. I have a 97 Eldorado ETC that has been sitting for the past 3 years and I finally have the funds to try to put it back on the road. The first engine had head gasket issues and was replaced with a second, used engine that lasted for about 2 years but its the same issue again with the head gaskets. So my question is, would it be wise to have an expert redo the gaskets or replace it with another used or reman engine?
    Any help would be greatly appreciated.
    98eldo32v's Avatar
    98eldo32v is offline Cadillac Owners Connoisseur
    Automobile(s): 98 eldo/KD54 w/N37,T96,QA1,D55,DS3,U1Z. U3R next
    Apr 2010
    51
    2,126
    Re: Looking for Northstar experts in or around Atlanta, GA
    Stud it, pm me
    68
    82,058
    Don't mean to rub salt in the wound, but if you had replaced the HGs on the first engine (properly) it would still be running without problems. This is a perfect example of the devil you know vs the devil you don't. I suspect it will be cheaper (not cheap) to replace the HGs than to replace the motor. Just be sure that whoever does it has done it before (on a Northstar) and will insert (NOT Helicoil) or stud all 20 bolt holes.
    98eldo32v's Avatar
    Apr 2010
    51
    2,126
    ^^^^^^^ that is correct Ranger.
    The engine should have been studded or inserted. I prefer the stud method.....
    May 2004
    Atlanta, GA
    Thanks for the advice Ranger,
    Unfortunately, I was ignorant to the fact and did not have all these great resources that I do now. Plus it was so hard to find someone that knew what they were talking about or doing in my area. I will get it right this time around and get the heads done.
    98eldo32v and 98eldo32v like this.
    beebop01 is offline Banned
    Automobile(s): deville
    Jun 2009
    42
    12
    I am driving thru Atlanta, GA in a couple week heading back to Indianapolis . I would be more than happy to pick the car up and fix it for you.
    Dollar Bill's Avatar
    Dollar Bill is offline Cadillac Owners Member
    Automobile(s): 2001 Eldo ETC, 1956 CDV, 1958 Biarritz
    Dec 2011
    Atlanta
    65
    Randy's Automotive in Marietta. Very knowledgeable, talk with andy or Carole. They only work on Cadillacs. Somewhat cheaper than a dealer. Very good.
    https://plus.google.com/101422684820...ut?gl=us&hl=en
    Also suggest getting into the Peach State Cadillac Lasalle Club. Contact Doug Bailey, for membership info, at the end of the link below. Very active club with a lot of members willing to help if you want to work on your own car.
    http://peachstateclc.com/index.htm
  10. Remove Advertisements
