Top Speed Reached - Fuel Pump Shutoff at 105mph?
Results 1 to 7 of 7
Northstar Engines and System Technical Discussion Discussion, Top Speed Reached - Fuel Pump Shutoff at 105mph? in Cadillac Engine Discussion; I have a 1996 Sedan Deville N*. A message appeared the other day stating that "Top Speed Reached" "Fuel Pump ...
    outlaw1369 is offline Cadillac Owners Member
    Automobile(s): 1995 Eldorado 1996 Sedan Deville
    Aug 2004
    New York
    57
    I have a 1996 Sedan Deville N*. A message appeared the other day stating that "Top Speed Reached" "Fuel Pump Shutdown". I was crusing along at 100-105mph when this happened. I have had the car up to 120mph in the past. Any ideas why this has happened? Vin is 1G6KD52Y7TU292694 how do I determine the HP\motor from the vin number? My girlfriend was in the glove box and my have pushed the valet button. Would this have any affect on the top speed of the car?
    STS 310's Avatar
    STS 310 is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 STS
    Dec 2003
    LOS ANGELES CA
    1,489
    Re: Top Speed Reached - Fuel Pump Shutoff at 105mph?
    Quote Originally Posted by outlaw1369
    1G6KD52"Y"7TU292694
    Vin Y engine
    Dont think the valet switch would affect the top speed shut off. I thought that 112 was the limit set for that engine.
    68
    81,894
    112 is my understanding as well but then when your at 105 what's another 7 MPH
    Aug 2004
    New York
    57
    Is there any way to change the top speed? I had the car up to 120mph in the past. I put new tires on the car and now it will only go 105mph. The old tires were the wrong size. How is the speed measured? Transmission? Crank sensor? Wheel sensor?
    STS 310's Avatar
    Dec 2003
    LOS ANGELES CA
    1,489
    In short, no. But, there is a company offering some mods to OBD II depending on your vin #. Havent heard of anybody on this board doing this yet. If you had the vin 9 300 HP engine, I believe it could be re-flashed to z rate which would elinate the speed limiter.
    Do a search, something like "top speed" or something to that affect. A thread dealing with this subject comes up very often.
    Funny thing is, the best option I have heard is to sell your car and apply proceeds to a vin 9 engine equiped model. Only thing is it has to be a "T" model ie. STS, DTS, or the Pre 93 non-N* Seville or Fleetwood with the LT1.
    68
    81,894
    All vin 9's are not unlimited. It depends on if the car came from the factory with "Z" rated tires. I think that was optional if I am not mistaken.
    STS 310's Avatar
    Dec 2003
    LOS ANGELES CA
    1,489
    Quote Originally Posted by Ranger
    You are rite Ranger. I have the Z rate, with out the Z rated tires rite now.
  10. Remove Advertisements
