01 STS - Head Gasket - Perm or Temp/Quick Fix Solution
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, 01 STS - Head Gasket - Perm or Temp/Quick Fix Solution in Cadillac Engine Discussion; Hi everyone, My 01 STS is done again. I bought it two years ago and head gasket blew on the ...
    ddzc is offline Cadillac Owners Member
    Automobile(s): 2001 Cadillac STS
    Jan 2010
    Toronto
    24
    Hi everyone,
    My 01 STS is done again. I bought it two years ago and head gasket blew on the first motor and because the price of fixing it was a lot cheaper to swap the motor, I did so. This new motor is now done as well, same head gasket problem.
    Couple questions:
    I'm in Ontario, Canada - Is their someone cheap that can replace the HG and get this running properly?
    - If I decide to scrap the car, is their a good head gasket repair kit to temporarily fix it, just so I get a few more mths out of the car perhaps. I was looking at steelseal and rislone products.
    Thanks everyone.
    Dan
    CadillacLuke24's Avatar
    CadillacLuke24 is offline Cadillac Owners Master
    Automobile(s): Alexandra - 96 SDV --- Clyde - 15 Silverado
    Jul 2010
    Wyoming
    26
    5,751
    Re: 01 STS - Head Gasket - Perm or Temp/Quick Fix Solution
    Go to Northstar Performance.com and research some options there. Local (AFAIK), and for a permanent fix, it's not too bad.
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,999
    I also suggest the above mentioned place. He knows every inch of a Northstar.
