Northstar head gasket problem
Results 1 to 9 of 9
Northstar Engines and System Technical Discussion Discussion, Northstar head gasket problem in Cadillac Engine Discussion; My friend has a gorgeous 1997 SLS with a big dilema. The engine is again leaking coolant from what appears ...
    featherfoot is offline Cadillac Owners Member
    Automobile(s): 1997 Seville STS
    Jul 2009
    15
    My friend has a gorgeous 1997 SLS with a big dilema. The engine is again leaking coolant from what appears to be another blown head gasket. This occured about a year or so ago and he paid a private Cady mechanic $4K to replace the head bolts, gasket, etc, etc, and all was fine until yesterday. Meanwhile, the mechanic who was a specialist in fixing this well known early Northstar problem has closed his business! The question is....is there another GM mill that can retrofit the Northstar, or is it time to give up? Seems most of these Northstar engines can't get past 100K mi. Replacing with a used one is a gamble and a new one might be way over budget. Any suggestions will be appreciated.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,173
    Re: Northstar head gasket problem
    A lot depends on where the car is and how far the owner is willing to truck it.
    Yes, if the basic engine is sound it can be satisfactorily overhauled and be guaranteed a long, powerful life. There are a couple of caveats - first is what system was used on the first head gasket repair ?? This MUST be accurately known in order to make recommendations for either keeping or scrapping the present cylinder block - you don't simply replace drilled/oversized/missing block aluminum.
    Your "friend" needs to talk basics with either Joe Blau at Midwest Cadillac Repair in IL or with Tim Carroll at Carroll Custom Cadillac in WA. Google each business.
    MOST Northstar engines get WELL past 100K miles - your case is one of a minority.
    Jul 2009
    15
    Thank you very much forn your reply. Much appreciated. I've passed the info along to my friend. Hope he can manage a fix, his SLS is really pristine. Almost as nice as my '97 STS (and I usually tell him so, with a chuckle). Problem is, this would be the second go around with this fix and he may be discouraged. Has anyone had success replacing a '97 engine with either a different GM engine, or a later model Northstar after the head bolt re-design was done?
    Thanks again!
    Feb 2006
    57,173
    Replace the 1997 VIN Y Northstar engine with a studded 1997 VIN Y Northstar engine............ period.
    (maybe not quite "period": That's a flat-tappet engine, so do a thorough valve train check and overhaul)
    69
    82,393
    Gotta wonder exactly how the first repair was done.
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,527
    I did the heads on my 96 STS 5 yrs ago. And changed the a/c compressor this may. So when my trans died last month I was a little bummed. Mostly cuz this was my first fwd subframe drop. If ur friend has to pay someone else to fix motor than it's a tough decision. Why is motor leaking? Bad insert? U are at point where u gotta love this car to fix it.
    DevilleDeeman's Avatar
    DevilleDeeman is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS4 Premium, Saturn Vue XR
    Sep 2008
    Ontario, Canada
    48
    483
    Bolts and thread sleeves have to be replaced, I believe there is a kit to be used otherwise the gasket will blow again.
    Reason for head gasket failure is the sub-par bolts and threads slip out of the aluminum block.
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,993
    Quote Originally Posted by DevilleDeeman View Post
    Not quite - that's still a mystery. No one knows which one came first - failed gasket or pulled bolts.
    Aug 2007
    mpls mn
    2,527
    U can find a dozen 97-99 similar caddies with great bodies and bad motors in any big city. U buy it for 600 and fix it and sell it for 2500. Yes a shop wants 2500 to fix it. Those are the basic facts. A properly repaired car with no other issues is worth something.
  12. Remove Advertisements
