Buyer beware
Results 1 to 7 of 7
Northstar Engines and System Technical Discussion Discussion, Buyer beware in Cadillac Engine Discussion; I am flying to Florida Sept 21st to visit and purchase a Cadillac and drive back to Nebraska for personal ...
    MANLEYONE is offline Cadillac Owners Member
    Automobile(s): 1993 FLEETWOOD
    Sep 2012
    70
    Buyer beware
    I am flying to Florida Sept 21st to visit and purchase a Cadillac and drive back to Nebraska for personal use. Money restraints put Me into the 2002/2003 Deville or Seville catagory with up to 130K. I'm led to beware of Northstar engines prior to 2002 to avoid overheating and head gasket problems. Any timing chain problems or buying advice or pitfalls to avoid? Thanks, Joe
    69
    82,171
    Re: Buyer beware
    Timing chains are almost bullet proof. The Northstar got lengthened head bolts in 2000 and a coarser thread pitch on '04. Just be sure it does not overheat (give it some WOT on the test drive) and there where no recent cooling system problems like a new radiator. If there are or where any mention or signs of overheating, run like a pair of cheap pantyhose.
    Submariner409's Avatar
    Submariner409 is offline If it won't run, stick on fender vents
    Feb 2006
    MD Eastern Shore, Kent Island
    56,590
    Re: Buyer beware
    Go up ^^^ to the top black bar and study the entire Cadillac Technical Archive - there is vital Northstar information in there. Then, go back down to Discussions, Cadillac Tech Tips and wade through the many pages of threads for items of interest.
    A GM dealer can be asked for the old GM "VIS" - the database printout of all warranty, recall, and some GM-performed work on the car. CARFAX is a voluntary reporting database, so the only info there will be registration changes, emissions tests, and a bit of other info someone wants you to know.
    Use the sticky post at the top of the Seville/Deville forums page "How to pull codes" - these cars have their own built-in code scanner/memory system, so if you have access to a laptop at a dealer's lot you can scan the car yourself, go to the sticky and open the link with "obd2" in the address and use that to translate every P, B, C, and U code in the car's memory. Codes will show as Current or History.
    Cold, open the coolant reservoir - the orange coolant should be absolutely clear and clean. ANY clue of mud, chips, flakes - walk. The reservoir should be half full, cold - no more than that. The engine oil should be clean with little or no smell. About halfway up the hashmark is the proper fill level. The engine takes exactly 7.5 quarts, with filter, of whatever 5W-30 oil floats your boat. Try to stay away from the Oil Doodle - do the oil/filter yourself and learn about the car..................
    Stay away from any FWD Cadillac on the Korner Kar Korral or someone's front lawn: If the deal is too good to be true, it is.
    ELDO GUY's Avatar
    ELDO GUY is offline Cadillac Owners Fanatic
    Automobile(s): 2K ELDO WHITE DIAM , 2K TURBO BUG ,69 VETTE ZZ4 2014 CTS
    Sep 2004
    SKOKIE ,iLL
    66
    450
    Re: Buyer beware
    Why not get a block test kit about, 30 bucks and bring it with you. Cheap insurance and it can be done in under 10 minutes.
    69
    82,171
    Re: Buyer beware
    Or borrow one from AutoZone and just pay for the test fluid.
    98eldo32v's Avatar
    98eldo32v is offline Cadillac Owners Connoisseur
    Automobile(s): 98 eldo/KD54 w/N37,T96,QA1,D55,DS3,U1Z. U3R next
    Apr 2010
    51
    2,126
    Re: Buyer beware
    Take it out on the highway, give a few good blasts of the throttle and back to cruising speed fully warmed up.
    If it starts to overheat you start negiotaing or start planning your trip back home.
    SC2150's Avatar
    SC2150 is offline Cadillac Owners Connoisseur
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    60
    1,833
    Re: Buyer beware
    Follow submariners suggestion and you will learn a ton....and first thng flush the coolant and refill fresh!
  10. Remove Advertisements
