Northstar - any thoughts or advice ????
Results 1 to 11 of 11
Like Tree2Likes
  • 2 Post By codewize
  • 2 Post By Submariner409
Northstar Engines and System Technical Discussion Discussion, Northstar - any thoughts or advice ???? in Cadillac Engine Discussion; Hello all, Can anyone give me the lowdown on the northstar? I have heard both sides, but looking for more ...
    joanscar is offline Cadillac Owners Member
    Sep 2012
    1
    Hello all,
    Can anyone give me the lowdown on the northstar? I have heard both sides, but looking for more info. I am looking at a 1998 deville.
    THanks
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,370
    Re: Northstar
    everything you could possibly want to know
    about the Northstar motor can be found here:
    http://www.cadillacforums.com/forums...al-discussion/
    blalockchiro's Avatar
    blalockchiro is offline Cadillac Owners Fanatic
    Automobile(s): 1997 Deville, 89 Camaro, 07 Silverado
    May 2011
    macon, ga
    363
    i have a 97 basic deville with a N* V8, i have had the car for 15 months now. i bought it with 103,000 miles on it. the car itself has been excellent, great ride. i did all the basic maintence stuff when u got it. the only major problem i have had is the water system. the water pump went out, changed, the radiator started leaking...changed...then at the beginning of the past summer it major overheated...i had to tighten all the hoses....and that is it,,,the best thing is, the car will tell u what is wrong with it by codes...best car i have ever bought!!!!!!
    Slipgate is offline Cadillac Owners Enthusiast
    Automobile(s): 1998 Deville
    Jul 2009
    48
    710
    Re: Northstar
    98 is what I have. I got it with no knowledge of the N*'s issues. The guy that sold it to me thought it had a blown head gasket which he did not tell me about. It turns out it had a leaking water pump and a rusted out metal crossover pipe that goes behind the engine. Water pump cost me $300 to have done and I bypassed the metal pipe for $40. I have put around 20k miles on it with no real issues beyond what I initially did. I did replace all 4 wheels due to air leaking out from rusted beads (common issue), all 4 rotors and pads, a new battery, and the drivers door window motor. It is my daily driver at this point.
    Major Design Flaws/PITAs:
    Coolant parts that you can't get to without removing the engine
    oil fill hole directly above alternator - any spilled oil can cause the alternator to prematurely fail
    generally hard to do anything on the engine due to access issues
    You should not pay more than $1500 for it unless it is showroom condition and then maybe $2k.
    Jul 2009
    48
    710
    Re: Northstar
    Quote Originally Posted by blalockchiro View Post
    Hey are you a Blalock? I am related to some Blalocks that hail from AL/FL area.
    May 2011
    macon, ga
    363
    Re: Northstar
    slip, i sent you a PM
    89falcon is offline Cadillac Owners Fanatic
    Automobile(s): my wife crazy, 1997 STS, 2004 CTS
    Apr 2011
    188
    Re: Northstar - any thoughts or advice ????
    Just as a warning.....often...the reason things start failing in the cooling system is because it's being over pressurized by a leaking HG......
    sounds like a slow leak......
    codewize's Avatar
    codewize is offline Cadillac Owners Master
    Automobile(s): 91 Brougham d'Elegance / 95 Fleetwood Broug/ 01 DTS / 11 CTS Lux
    Apr 2005
    Upstate NY
    50
    6,919
    Someone here once said, and if I could remember who I'd credit them but they said
    Owning a N* without a warranty is like running through a Bosnian minefield. Exhilarating but deadly.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,904
    Nope, it's the parallel to the ocean racing sailboat owner/crew's explanation -
    Like running around stark naked in a cold shower, all the while screaming at the top of your lungs and tearing up $100 bills.
    codewize's Avatar
    Apr 2005
    Upstate NY
    50
    6,919
    Yup, that too.
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
    U can say any cars value is based on miles and condition. Is this 98 a low miles jewel? 75k miles vs 155k miles is a big diff. Great paint or so-so? New tires? Nice interior?
  14. Remove Advertisements
