Results 1 to 6 of 6
Thread: 1999 Deville PCM codes - can you tune it?
    SUPER LAC DEVILLE's Avatar
    SUPER LAC DEVILLE is offline Cadillac Owners Enthusiast
    Automobile(s): 1998 Cadillac Deville
    Aug 2012
    Tampa Florida
    38
    854
    ok
    so i have a PCM code(s)
    my 98 deville is sucking premium gas at 12mpg
    does it need retuning or should i go rip one out the junk yard to jus replace it?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,854
    Re: 1999 Deville PCM codes - can you tune it?
    Hiya - Welcome Aboard !!!
    This was moved from "PCM tuning" because your question is not about the possibility of "tuning" your PCM for high performance.
    You have codes - what are they and what are the code definitions ?? Your gas mileage is horrible, so you probably have multiple problems - none of them with the PCM itself. The "P" in the codes refers to the basic system in which the code is, the code number itself is the fault locator. Use the sticky post ^^^ "How to pull codes" and study the section for your car, year group and dash button layout. Get any codes stored, write them down with the suffix - Current or History - and return to the sticky to open the link with "obd2" in the address - that takes you to a Master Index of all P,B,C, and U codes. decipher all your codes and post it all here.
    A "new" PCM for your car must be programmed by a GM dealer - that box is flashed for YOUR car and your car only.
    69
    82,278
    Also check for a leaky FPR.
  5. #4
    Aug 2012
    Tampa Florida
    38
    854
    Quote Originally Posted by Ranger
    PLEASE I didn't mean to offend you, sir.
    I jus wanted help with my car.
    And What is the FPR?
    I bought a 1980-2009 Cadillac Service Repair Manual (DVD Rom) and check the codes.
    I had my mechanic friend look up the codes and he figured out my PCM codes.
    One was from a bad battery ground. A short kept resetn my system.
    The other has to do with Torque converter clutch solenoid stuck open/closed. He told me I should sell my car bc it's a transmission related problem.
    I fix the Battery ground and reset the PCM codes. Did a errand this morning and no codes.
    Gas milage was at 15.5 when I got home but my Mechanic friend says I'll have to drive a few days for the computer to relearn all over again.
    HP was way better too, sometimes it felt like a turbo kicked in. Had me a lil shaky at first bc I wasn't use to the power being at the gas pedal in a long time.
    Any thoughts, sir???
  6. #5
    Feb 2006
    56,854
    FPR - Fuel Pressure Regulator. Under the engine beauty cover, on the right (rear) run of the fuel rail - the silver domed thingy with the vacuum line sticking out the side. Carefully remove the vacuum line - any raw gas drip out of the nipple or line ? That would indicate a ruptured inner diaphragm . If so, replace the unit. Hairpin clip, pull it out - 2 O-rings on the body. Make sure the lower one comes out. Oil the new unit O-rings, press it in, clip. Hook up vacuum.
    You didn't offend anyone - we all recommend checking the FPR during checks for poor gas mileage. Your car should get about 12 - 16 mpg city, 17 - 21 suburban, 25 - 27.5 long open highway runs.
    Your instrument panel (DIC) fuel mileage readouts - instant, average, range, fuel used - change as conditions change. The average and gallons used can be reset - read your owner's manual. Understand that instantaneous mileage is for fun: it is worthless in calculating true gas mileage. The average - long term - mileage is the one to use.......... But understand that it's a long term average: You reset it and start the engine and sit at idle - your gas mileage is 0. Get out on the Interstate at 65 for a half hour and it should slowly click up to the high 20's. The longer you drive, under all conditions, the more accurate the average overall gas mileage will be.
    EDIT: Go up a thread or two from this one - read the sticky posts there - Acronyms, for one. You'll see a LOT of abbreviations used here and in the (real) GM/Helm service manual hard copy.
  7. #6
    69
    82,278
    Quote Originally Posted by SUPER LAC DEVILLE View Post
    Not sure what you are talking about. I see nothing to take offense from.
  • You may not post replies
