How do I drain ALL the coolant? - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 23 of 23
Like Tree9Likes
Northstar Engines and System Technical Discussion Discussion, How do I drain ALL the coolant? in Cadillac Engine Discussion; 6 qt is spot on for a drain and refill. You wont' get it all out. If you're concerned about ...
  1. #16
    codewize's Avatar
    codewize is offline Cadillac Owners Master
    Automobile(s): 91 Brougham d'Elegance / 95 Fleetwood Broug/ 01 DTS / 11 CTS Lux
    Apr 2005
    Upstate NY
    50
    6,919
    Re: How do I drain ALL the coolant?
    6 qt is spot on for a drain and refill. You wont' get it all out. If you're concerned about it that much, drain and refill again in 3 or 4 months.
  2. #17
    CadillacLuke24's Avatar
    CadillacLuke24 is offline Cadillac Owners Master
    Automobile(s): Alexandra - 96 SDV --- Clyde - 15 Silverado
    Jul 2010
    Wyoming
    26
    5,740
    I'm not too terribly concerned. I look at it like this: I was able to get most of it exchanged, and what I didn't get out is mixed quite nicely with newer stuff due to my old attempt. It will get me to the next change plenty fine
  3. #18
    Tom's Caddy's Avatar
    Tom's Caddy is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 CTS/ 2008 DTS/ 2008 STS V8 N*/ 2011 CTS4 ALL W/D Pearl
    Jul 2012
    Ontario, Canada
    680
    When I take mine to the Cadillac dealer and they charge me $130.00 dollars are they getting it all out, what is diffrent that they do, I've never watched or asked my bad.
  5. #19
    Jul 2010
    Wyoming
    26
    5,740
    They're humans, so I'd imagine the answer is a resounding NO. I will do a write up of how I did it. If you get to it while the car is cold, it's not a big project at all.
  6. #20
    68
    81,928
    Quote Originally Posted by Tom's Caddy View Post
    The dealer MAY use a machine to do a "fluid exchange". IF they do, they pump new fluid in and old fluid out. Theoretically, that should replace all the fluid, but the fluid can take more than one route when being pumped into the system so exactly how effective it is I could not say.
  7. #21
    Jul 2012
    Ontario, Canada
    680
    Thank you Ranger. I think you are right about a machine. I will call the dealer to confirm. I called and they said they always use a rad flush machine which works on vacuum, they say it gets 99% of the fluid.
  8. #22
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,919
    Google "automotive coolant vacuum flush machine".
    Most dealers use a version of the QuickDraw.
  9. #23
    codewize's Avatar
    Apr 2005
    Upstate NY
    50
    6,919
    I'm not interested. I think it's safer just to drain and refill. Any forcing of anything in an engine prone to gasket failure can't possibly help anything.
    Same with the transmission on these. Never ever have a flush done. Just drain and refill, replace the filter.
  10. Remove Advertisements
