heater tube connection leak
Results 1 to 2 of 2
Northstar Engines and System Technical Discussion Discussion, heater tube connection leak in Cadillac Engine Discussion; Just fired up my 2001 Deville after headgasket/studding repair and noticed I have a coolant leak out of heater tube ...
    trbolvr is offline Cadillac Owners Member
    Automobile(s): 2001 Deville
    Aug 2011
    Duluth, Mn
    7
    Just fired up my 2001 Deville after headgasket/studding repair and noticed I have a coolant leak out of heater tube at crossover connection.
    Attachment 94469
    It is leaking out of connection point of item 1 and 2 in this diagram.
    Anyone know what the method of sealing is here? Oring perhaps? Thanks.
    BTW engine fired rite up and ran good
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,875
    Re: heater tube connection leak
    GM quick connect with nylon snap fingers and O-ring. Replacement fittings on the Help! racks at large parts stores. Your diagram is correct.
