small coolant drip where sensor mounts
Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Like Tree1Likes
Northstar Engines and System Technical Discussion Discussion, small coolant drip where sensor mounts in Cadillac Engine Discussion; Hello Everyone, I have looked at alldatadiy but cannot find the part where the drip originates. It is on the ...
    eldoedwardo is offline Cadillac Owners Fanatic
    Automobile(s): '99 Eldorado coupe
    Mar 2011
    KCMO
    63
    161
    Hello Everyone,
    I have looked at alldatadiy but cannot find the part where the drip originates. It is on the even numbered side below the head about one inch. From the ( bottom looking up) it appears to be one of the threaded sensors ( upper one) just to the left (towards the passinger side) of the oil filter. It's not dripping real bad like in an hour there is a puddle, but I would like to investigate it.. It is not spraying just dripping.
    thanks, ED
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,148
    Re: small coolant drip where sensor mounts
    Picture................There aren't any sensors on the passenger side of the oil filter adapter. Just the alternator and oil level switch. The CKP's (CranKshaft Position sensors) are just on the driver's side of the filter adapter, on the block.
    Coolant drip - does your car have a coolant-cooled alternator ?? Don't think so..........
    69
    82,386
    I think the '99's DID have a water cooled alternator.
    CadillacLuke24's Avatar
    CadillacLuke24 is offline Cadillac Owners Master
    Automobile(s): Alexandra - 96 SDV --- Clyde - 15 Silverado
    Jul 2010
    Forever West
    26
    5,772
    Northstar V8s were introduced with water cooled alternators as an aid for the electronically laden Cadillacs they powered. In the 2000 model year update, the water-cooled alternators were deleted in favor of simpler, less leak-prone, air cooled alternators.
    69
    82,386
    I don't think the water cooled alternators where introduced until about '99 (maybe '98). They where short lived and only lasted about 3 years.
    Mar 2011
    KCMO
    63
    161
    Thanks everyone,
    After looking again it seems to be around the CKP sensor B. Is this something I should be concerned about asap? I generally drive around 50miles a day but if I choose to take a 300+ I dont want to replace it on the road. Do they leak then malfunction, or is it just a drip not to freak-out over, or is just something to keep an eye on? Will it run without that sensor working? If the sensor should malfunction woud it be wise to replace them both?
    Thanks for the help. Also it isn't a water cooled alternator, it is a 'y' coded N* assembled in January of '99.
    Have a great 4TH of July!!! America,America, MY HOME sweet home.
    69
    82,386
    CKP sensors don't usually leak, but even if it does, it won't leave you stranded. They just get intermittent (occasionally stall at a light, hard starting, and give a momentary power loss while driving). If you do change them, definitely do both, but the '99 is not known for failures like the 2000-2003's (just replaced mine).
    No water cooled alternator on a '99? Maybe because it is an Eldo vs Seville.
    Feb 2006
    57,148
    CKP's use an O-ring as a seal - no pressure or stress to speak of. The weep will gradually get worse over time (long time) but it won't suddenly go. There's no coolant associated with a CKP.
    IF one CKP went bad - totally bad, as in: sensing no trigger signal - then the PCM defaults the ignition to "limp home" mode. Timing goes static at 10 degrees BTDC, the engine will run OK but will lack power and feel unresponsive.
    JoeTahoe is offline Cadillac Owners Enthusiast
    Automobile(s): 2001 GMC SLT, Malibu LTZ, 99 STS studded with NP
    Jul 2010
    Central, NY
    49
    499
    if I remember right there is no coolant around the crank sensors?? if it were a crank sensor o-ring it would be leaking oil
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,969
    Yeah my '99 deville doesn't have a water cooled alternator
    Jul 2010
    Central, NY
    49
    499
    my 99 seville sts does, but my friends 01 esc eldo does not
    Sep 2007
    Wilmington, NC
    13,969
    Yeah i think only the seville ever had the cooled alternator
    Jul 2010
    Forever West
    26
    5,772
    My bad. I thought it applied across the board. Learn a little somethin' every day!
  16. #14
    69
    82,386
    I did as well. Basically the same engine in all the models.
  17. #15
    Jul 2010
    Forever West
    26
    5,772
    Yup, that's what I was thinking. They do share a lot of parts, such as bumper shocks.
  18. Remove Advertisements
