Size of hose used to connect heater line tubing
Results 1 to 8 of 8
Northstar Engines and System Technical Discussion Discussion, Size of hose used to connect heater line tubing in Cadillac Engine Discussion; Hi all, i was wondering if some one might know the diameter of the hose that is used to connect ...
    walliss34 is offline Cadillac Owners Member
    Automobile(s): 99 deville, 99 STS, both White
    Apr 2012
    Hudson Valley, NYS
    52
    86
    Hi all, i was wondering if some one might know the diameter of the hose that is used to connect the heater line tubes, there are 2 short pieces right above the park/neutral switch.
    Thanks!
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,871
    Re: Size of hose used to connect heater line tubing
    I would guess 3/4", but get to a NAPA store, pull a hose from stock and measure the ID.
    Apr 2012
    Hudson Valley, NYS
    52
    86
    Thanks Sub, had my wife measure it, the tube is 1" and the id of the hose is 3/4" I was not sure how many different sizes of hose there is but i know what to get now, Thanks again.
    tateos's Avatar
    tateos is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 ETC (GAVE TO STEPSON 2011), 2000 DTS (RIP)
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,704
    You're supposed to use a special silicone hose there, but I've used regular heater hose there with no problems
    JoeTahoe is offline Cadillac Owners Enthusiast
    Automobile(s): 2001 GMC SLT, Malibu LTZ, 99 STS studded with NP
    Jul 2010
    Central, NY
    48
    502
    Try to get silicon hose
    Apr 2012
    Hudson Valley, NYS
    52
    86
    Where can you get silicon hose? Advance Auto had lots of hose, but we had problems finding 3/4" ID, much less silicon hose. I did not see anything in the hose selection beside the common black heater hose.
    Feb 2006
    55,871
    The silicone hose was used in an attempt to increase heat resistance and life. If you have to, use good ol' black heater hose with good clamps and slip a length of cutesy braided silver covering over each piece..............
    Jul 2010
    Central, NY
    48
    502
    i believe napa has it or a truck shop should have silicon
  11. Remove Advertisements
