Top pullers, I need help with a bolt
Results 1 to 7 of 7
Like Tree1Likes
  • 2 Post By ternstes
Northstar Engines and System Technical Discussion Discussion, Top pullers, I need help with a bolt in Cadillac Engine Discussion; I only have a few more things to go, then I can yank this motor out. BUT... How. In. The. ...
    andyoww's Avatar
    andyoww is offline Cadillac Owners Member
    Automobile(s): 1997 Deville http://img.ly/7HqE
    Aug 2011
    Muscoda, WI
    43
    33
    BUT...
    How.
    In.
    The.
    Blue.
    Blazes.
    Do I remove the transmission to engine bolt that is closest to the driver?
    I think I finally found it, (directly below the water pump housing) but how have you people been able to remove it?
    The others were 18mm, but this one looks smaller.
    I would love the head size as well.
    Thanks in advance.
    ternstes is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS V, 2007 SRX V8, 2005 CTS 3.6L, 2000 STS, 1999 STS
    Nov 2008
    SW Ohio
    36
    394
    Re: Top pullers, I need help with a bolt
    If you are talking the bell housing bolt closest to the firewall, it is a 15 mm socket. Find the shortest ratchet/socket combo you have and see if it clears the space. I am not sure if a 15mm wrench can work, but if you get it on the bolt head, hook another long wrench onto it for more leverage.
    The other thing you could try is removing the water crossover for some extra room..........
    97EldoCoupe and 97EldoCoupe like this.
    97EldoCoupe's Avatar
    97EldoCoupe is offline Cadillac Owners Connoisseur
    Automobile(s): 97 ETC x2, 04 GXP, 04 STS x2, 97 ESC, 99 Deville, 05 SRX
    Mar 2007
    London, Ontario and Winkler MB
    31
    2,621
    Ratcheting wrench is what I use, long to loosen, stubby for more swing. 15mm as Ternstes had mentioned
    83CADMAN's Avatar
    83CADMAN is offline Cadillac Owners Fanatic
    Automobile(s): 83 Eldorado, 90 Seville, 94 Concours
    Jun 2009
    Pacific Northwest
    62
    467
    Ah...Ratching wrench. I'm off to harbor freight. Thanks Jake.
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,873
    Quote Originally Posted by 83CADMAN View Post
    My harbor freight ones broke when i pulled that bolt. Get a craftsman
    andyoww's Avatar
    Aug 2011
    Muscoda, WI
    43
    33
    Thanks.
    I was able to get the bolt out, but only after removing the water pump housing.
    I didn't realize I needed to remove the shift cable & mount to get the big electrical cable out of the way, otherwise I may have been able to get it without taking the housing off.
    15mm was right.
    83CADMAN's Avatar
    Jun 2009
    Pacific Northwest
    62
    467
    Quote Originally Posted by vincentm View Post
    Thank for the heads up.
    I Took a good hard look at my own N* to locate the bolt in question. I found it easy enough but the two bell housing bolts at the top, under the crossover, were completely backed out of their respective threads, just hanging loose like they were never threaded in. The threads on the bolts were clean; the bolt head had no tool scratches and looked like brand new bolts. I am not sure what to make of it???? 117k miles on a one-owner car that has never had the engine removed. Wow I wonder if the car made off the assembly line that way?
  10. Remove Advertisements
