Water pump tool
Results 1 to 10 of 10
Northstar Engines and System Technical Discussion Discussion, Water pump tool in Cadillac Engine Discussion; Yes I started a prohect w/o all the tools. Now I am tryig to find a place that has the ...
    Rhoades is offline Cadillac Owners Member
    Dec 2004
    1
    Water pump tool
    Yes I started a prohect w/o all the tools. Now I am tryig to find a place that has the water pump removal tool. Every place I ask looks at me like I have a 3rd eye in the middle of my forehead!! Do any of you know who might carry the damn thing??? I am in the Twin Cities if that matters.
    Rhoades
    chazglenn3's Avatar
    chazglenn3 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 White Diamond STS N* 1SF RWD ACC/HUD
    Sep 2004
    Tacoma, WA
    54
    1,941
    Re: Water pump tool
    It was my understanding that Autozone stores carried the tool. As a last resort, you can most likely get from the the nearest Caddy dealer.
    Charles :greendude
    68
    81,914
    Re: Water pump tool
    Here's one option.
    http://www.caddyinfo.com/toolrental.htm
    Also most online tool sites. Harbor freight, The Tool Warehouse, Snap-on just to name a few.
    Katshot's Avatar
    Katshot is offline Cadillac Owners Master
    Jan 2003
    Newtown, PA
    58
    6,472
    Re: Water pump tool
    Call 1-800-GM-TOOLS
    Sorry they don't do web-based ordering.
    Gunny is offline Cadillac Owners Member
    Nov 2004
    8
    Re: Water pump tool
    Amazon.com sells the tool you need.
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,213
    Re: Water pump tool
    When you do get the tool, on this forum somewhere I saw that you are dealing with left hand thread. Just a suggestion.
    mcowden is offline Cadillac Owners Connoisseur
    Jun 2003
    1,164
    Re: Water pump tool
    I've borrowed the tool (with a small, completely refundable deposit) from both AutoZone and Pep Boys. It's just called a water pump tool. To get the pump out, you have to turn it clockwise, which is opposite what you'd think. If you turn it counterclockwise, the housing and other things could be damaged. It took a bit of clockwise force to break it loose, but it doesn't turn far once it starts moving, then it just pops right out of there. When you put it back in, turn it counterclockwise, but you should be able to see the tabs and how far it needs to go. Don't overdo it.
    Michael
    Mike
    68
    81,914
    Re: Water pump tool
    Quote Originally Posted by dkozloski
    It is not threaded. It is a cam lock. Only takes about 1/8 - 1/4 of a turn.
    MightyBright1's Avatar
    MightyBright1 is offline Cadillac Owners Member
    Sep 2004
    West Virginia
    48
    65
    Re: Water pump tool
    I would have sent you mine if you paid shipping. But glad you found one cheap. I turned mine the wrong way taking it out and broke one of the tabs on the housing. Needless to say it was a bitch taking it out. I then over tightend the new one and flatened the tabs. I figured "hey it a N*" and left it be. So far so good. No leaks. Go figure. Just figured I would share this story for the next guy who has to change one......
    tco43 is offline Cadillac Owners Member
    Jan 2004
    81
    Thumbs upRe: Water pump tool
    I bought the water pump replacing tool from NAPA--part # LS14440 Lisle tools---$24.95
    Worked like a charm.
  13. Remove Advertisements
