2000 Deville shakes at Idle, No DTC's
Results 1 to 7 of 7
Northstar Engines and System Technical Discussion Discussion, 2000 Deville shakes at Idle, No DTC's in Cadillac Engine Discussion; My car has recently started to run pretty crappy. I have already done the plenum and intake gaskets as well ...
    postman2000's Avatar
    postman2000 is offline Cadillac Owners Fanatic
    Automobile(s): 1996 STS 2000 Deville
    May 2009
    296
    My car has recently started to run pretty crappy. I have already done the plenum and intake gaskets as well as the injector o-rings. I have no codes other than a convertor code which has been there for two years. In the absence of codes, what do you guys think I should check? I appreciate any and all help..Thanks..
    69
    82,185
    Re: 2000 Deville shakes at Idle, No DTC's
    How old are the plugs? Did you clean the TB? Are all the vacuum hoses tight?
    May 2009
    296
    Yes the vacuum hoses are tight and I cleaned the TB. I did the plugs about 55,000 miles ago and used the AC Delco ones
    69
    82,185
    Bad coil maybe?
    May 2009
    296
    I also cleaned the Idle Air Control valve. I guess I'll be throwing parts at this car too..Even if I take it to a mechanic they gonna do the same thing because theres's no codes to point them in the right direction..I have seen it happen all too much...
    69
    82,185
    You could go to a junk yard and pick up a used ignition cassette cheap and swap them out one at a time to see if that solves the problem.
    May 2009
    296
    Yeah I think that's a good idea.. I just may do that
  10. Remove Advertisements
