Northstar interesting stuff....
Results 1 to 14 of 14
Northstar Engines and System Technical Discussion Discussion, Northstar interesting stuff.... in Cadillac Engine Discussion; interesting info on this motor during development...... http://history.gmheritagecenter.com/..._for_Northstar...
    98eldo32v's Avatar
    98eldo32v is offline Cadillac Owners Connoisseur
    Automobile(s): 98 eldo/KD54 w/N37,T96,QA1,D55,DS3,U1Z. U3R next
    Apr 2010
    51
    2,126
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,881
    Re: Northstar interesting stuff....
    Looks like, after 20 years, the head gaskets tolerate rocking loads in the vicinity of the front motor mount - but the front mount design is junk.
    Faded Crest's Avatar
    Faded Crest is offline Cadillac Owners Connoisseur
    Automobile(s): '66 SDV, '76 CDV, '89 BRM, '92 BRM, '98 Concours, '00 SDV
    Apr 2008
    North Carolina
    45
    3,222
    I wonder how many people are driving around with bad motor mounts and don't even know it. And I wonder how much that would contribute to head gasket problems. If there is more stress with a healthy motor mount, I wonder what those numbers would look like with a broken one.
    ternstes is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS V, 2007 SRX V8, 2005 CTS 3.6L, 2000 STS, 1999 STS
    Nov 2008
    SW Ohio
    36
    394
    I have torn apart three northstars and all have had their failures on the rear head gasket/block. Two with coolant visible in the number 1 cylinder, and another with a block crack between the 3 and 5 cylinders. Not scientific by any means, but it's odd. All 3 had front mounts that were shot as well. I can see the dilemma, though. A more solid mount would transmit more engine vibration to the frame and thus to the occupants.
    Apr 2008
    North Carolina
    45
    3,222
    Same thing on the '98 ETC I am working on. Totally torn front mount and the rear head was the worst one. Talk about motivation to check y our motor mounts!
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,872
    I wonder now if I should have mine replaced lol
    68
    81,916
    Makes me wonder if that's why they eliminated the torque struts.
    vincentm's Avatar
    Aug 2010
    Kennewick WA
    38
    4,872
    I at least was given new torque struts with this new block, but new mounts...hmmm
    Apr 2008
    North Carolina
    45
    3,222
    Motor mounts much more important. I'd check 'em out. Not that you need to worry about head gaskets anymore...
    vincentm's Avatar
    Aug 2010
    Kennewick WA
    38
    4,872
    Quote Originally Posted by Faded Crest View Post
    \o/!
    Feb 2006
    55,881
    Consider that the engines fitted with either factory or fabricated torque struts (dogbones or rods) transmit ALL rotational torque to the left cylinder head and water crossover housing - and that the incidence of head gasket failure in these engines doesn't seem to be any more or less of a problem than engines without dogbones......................and with dogbones, the front motor mount is relieved of rotational torque stress............
    Apr 2008
    North Carolina
    45
    3,222
    ^^^ Unless they are worn out too. My '98 base Eldo had a bad front mount and two bad dog bones and it allowed for so much movement that it rocked back and rubbed a hole in the low side a/c line over time.
    Feb 2006
    55,881
    ................. Naughty, naughty ! Your bad ! Preventive maintenance would have saved the A/C line and a bunch of work.
  16. #14
    Apr 2008
    North Carolina
    45
    3,222
    ^^^LOL... Not me... Previous owner let that happen. I'm just the one who got stuck replacing the line... And the compressor!
  17. Remove Advertisements
