Northstar Water Pump Housing Replacment
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, Northstar Water Pump Housing Replacment in Cadillac Engine Discussion; Hey I'm having issues with the last bolt on my water pump housing. It is located in a very tight ...
    jashcandymatt is offline Cadillac Owners Member
    Automobile(s): 1996 Sedan DeVille
    May 2012
    34
    1
    Hey I'm having issues with the last bolt on my water pump housing. It is located in a very tight spot where I can't reach. Please help
    68
    81,917
    Re: Northstar Water Pump Housing Replacment
    Moved from Tech Tips.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Would it happen to be one of the two bolts on the lower left (looking from the rear of the engine) "leg" of the crossover? The section of engine compartment harness that lays across the transmission, is right in the way of the lower bolts. You can unbolt a couple of grounds to gain a little slack to move the harness around a bit.
    Are you using a swivel head, ratcheting wrench? If not, GET ONE!!! It will make things SOOO much easier.
