my 1995 Cadillac Eldorado Overheating
Results 1 to 5 of 5
Northstar Engines and System Technical Discussion Discussion, my 1995 Cadillac Eldorado Overheating in Cadillac Engine Discussion; I bought this car in February 2012. The car ran fine and than it overheated. I took it in and ...
    Jaronj21 is offline Cadillac Owners Member
    Automobile(s): 1995 Cadillac Eldorado
    May 2012
    26
    1
    I bought this car in February 2012. The car ran fine and than it overheated. I took it in and Brake Plus ran a lot of test. The found no leakage from the pressure test. The Fans works and the water pump worked. They found no temperature differences when the ran the test on the radiator. Removed the thermostat replaced it and said i should consider replacing the eater pump belt it has cracks but i was told it was fine for a while. Two days later the car overheated AGAIN. Took it in and was told that oh, it was just air in the radiator that has busted but it shouldnt of been in there because the guy who fixed it should of drove the car to test is. He didnt so Brake Plus told me i will have 20% from future work on car. Shortly after the 2nd time i took it in i started seeing white smoke. Took it back into the shop and was told a gasket was bad. I feel like i should sue brake plus if this is the case because they told me the car was fine? do i have a case? but also i used blue devil gasket sealer car has no over heated but temperature goes up and does go back down to normal temp 196 -205. Is the gasket blown, did the sealer not work? Is there other things i can do to cure this problem? or was i simply sold a lemon???
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    Re: my 1995 Cadillac Eldorado
    Blue Devil and other products like it do not work on NorthStar head gaskets
    all the info you need to fix the car properly has been posted here (asked and answered and documented while being fixed) thousands of times
    most cadillacs for sale on the used market are for sale because something is wrong ... either the suspension or the engine (both the more expensive repairs these cars can need)
    i can't really comment on if you have a case against the shop but it does sound like they either don't know a thing about that car at all or they were lying to you
    i'd tend to fall on the side of ignorance and they just don't know (lots of well seasoned mechanics don't know how to diagnose or work on these cars)
    others here will probably tell you to confirm that it is the headgaskets on your own with a 'block test' (key words to search for)
    i would suggest that you check the 'purge line' first ... another key word to search for
    68
    81,883
    do i have a case?
    Check with a lawyer. Any legal advice you get here is worth exactly what you pay for it.
    Probably.
    Faded Crest's Avatar
    Faded Crest is offline Cadillac Owners Connoisseur
    Automobile(s): '66 SDV, '76 CDV, '89 BRM, '92 BRM, '98 Concours, '00 SDV
    Apr 2008
    North Carolina
    45
    3,222
    Re: my 1995 Cadillac Eldorado Overheating
    Sue them for what? Giving you a wrong diagnosis? If you could sue for something like that nobody would open an auto repair business.
    Forget about that crap and concentrate on finding out what is wrong with your car. The definitive test is a block test. Check the purge line like Chris said, but don't get your hopes up. You might be a new member of the blown head gasket club.
    Just so we are all on the same page, what is the temp. when the car is running hot? Does it say "stop engine" "Overheated" or are you just going by the temp?
    bill buttermore is offline Cadillac Owners Fanatic
    Automobile(s): 1998 DeVille 130K (Sold to Son)
    Sep 2011
    Ames, Iowa
    317
    The white smoke is a strong indicator that coolant is entering the combustion chamber, most likely through a failed head gasket.
  8. Remove Advertisements
