Seafoam - do you use it?
Results 1 to 14 of 14
Northstar Engines and System Technical Discussion Discussion, Seafoam - do you use it? in Cadillac Engine Discussion; Sometimes I put that stuff in the gas tank and crankcase a week or two before an oil change to ...
    weister42 is offline Cadillac Owners Enthusiast
    Automobile(s): 1998 Cadillac Deville Sedan
    Feb 2005
    897
    Sometimes I put that stuff in the gas tank and crankcase a week or two before an oil change to help clean things up, but I've never tried to put that through the engine's vacuum hose. Which vacuum hose do I use?
    ternstes is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS V, 2007 SRX V8, 2005 CTS 3.6L, 2000 STS, 1999 STS
    Nov 2008
    SW Ohio
    36
    394
    Re: Seafoam - do you use it?
    Easiest way is through the brake booster hose. Do not let the engine suck up too much fluid at once, and you may want to change your spark plugs afterwards.
    bill buttermore is offline Cadillac Owners Fanatic
    Automobile(s): 1998 DeVille 130K (Sold to Son)
    Sep 2011
    Ames, Iowa
    317
    I like the idea of getting the carbon off the valves and out of the intake manifold, but have not done the vacuum line method for fear of all the loosened crud fouling the oxygen sensor(s) and catalytic converter. I have only had enough nerve to put the stuff into the fuel tank for a more gentle (and probably less thorough) cleaning.
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,873
    Ill never use that crap on my engine or any engine.
    dkozloski's Avatar
    dkozloski is online now Cadillac Owners 10000+ Posts
    Jul 2004
    Fairbanks, Ak
    28,263
    What has worked for a good removal of engine carbon for the last 100 years is to spray water from a spray bottle into the engine air intake after removing the air filter. Have the engine running at 1200-1500RPM. Don't spray enough to stall the motor. Black smoke will roll out of the exhaust and then will cease as the engine cleans up.
    Don't mess with Binky Bear!
    Big Pip's Avatar
    Big Pip is offline Cadillac Owners Fanatic
    Automobile(s): '72 Coupe DeVille
    May 2008
    Central FL
    104
    Quote Originally Posted by dkozloski View Post
    I used to use this method on my old race car and it worked, hands down. BUT, after I started using seafoam, it worked better and I have used it in everycar since for the past 8 years. Just pour it down the carb while reving it up. I have seen some drastic changes in some cars with Sea-Foam.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,564
    Quote Originally Posted by Big Pip View Post
    I'll bet you have.........considering the OP's engine is not carbureted: His engine has a runner style intake manifold with a center log feed. The chances of hydrolocking the engine if using the brake booster vacuum line (at the throttlebody) are very, very good. The "cleaner" simply pools in the bottom of the manifold and creates copious amounts of warm, fuzzy smoke, so it MUST be doing something (other than destroying an engine that was good in the first place).
    Well marketed snake oil. OK for cleaning lawnmower engine parts.
    The picture is of a Northstar intake manifold sitting on the center intake log - that space will easily hold 2 quarts of anything BEFORE any of it ever gets to a cylinder. Be very, very careful; of what you dump into a Northstar. You may pay dearly for the fun......... Just sayin'......
    EDIT: Just stuck in another picture of the manifold upside down - the center feedlog is clearer...........
    69
    82,155
    Quote Originally Posted by vincentm View Post
    AMEN!!
    Quote Originally Posted by weister42 View Post
    What makes you think it needs to be cleaned up?
    Feb 2005
    897
    I donno guys, I wouldn't call Seafoam "snake oil" because it does what it does, now how well does it do what it does varies from person to person but it does seem to get rid of the brown gooy substance (feels like slime) that was on the inner walls of my fuel lines (only noticed it when I changed the FPR). I always change the oil soon after though.
    Feb 2006
    56,564
    If you have "brown gooey substance - slime" on your fuel line walls (???), then you have much larger problems than "Seafoam" can cure.
    69
    82,155
    I'll drink to that.
    ThumperPup's Avatar
    ThumperPup is offline Cadillac Owners Master
    Automobile(s): not anymore 2007 Lexus ES350
    Mar 2009
    Murray/ Snowbird Utah
    37
    7,696
    ill never yous that crapp in my cadillac
    now in my old lincolns i used it all the time never had a problem ok not all the time but twice a year every 20k or so
    never once had a issue with it
    used it in the caddy once and omg she rann like shit she was bitching at me for an entire day almost
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    17xK Miles, never added into the engine anything but 10W30 regular oil and premium gasoline.
    No knock, no squeak, no shake, runs like in the first day.
    Why would I put that crap into the engine?
  16. #14
    Feb 2006
    56,564
    61,500 on the STS, 88,000 on one truck, 135,000 on the other - and roughly equivalent mileage on other vehicles back to 1955. Never poured a drop of Snakefoamoil in any of them. I truly wonder how the engines racked up all those miles without a hiccup without using those incredible aftermarket "cleaners" and "performance boosters" ? Just as N*Caddy, the engines never ran anything but the oil and gas recommended for each.
  17. Remove Advertisements
