WOT problem and P0300 - 2000 Eldorado
Page 1 of 5 1 2 3 4 5 LastLast
Results 1 to 15 of 69
Like Tree1Likes
Northstar Engines and System Technical Discussion Discussion, WOT problem and P0300 - 2000 Eldorado in Cadillac Engine Discussion; I have a 2000 ELDO esc with about 68k. owned the car since new and have kept up with all ...
    ELDO GUY's Avatar
    ELDO GUY is offline Cadillac Owners Fanatic
    Automobile(s): 2K ELDO WHITE DIAM , 2K TURBO BUG ,69 VETTE ZZ4 2014 CTS
    Sep 2004
    SKOKIE ,iLL
    66
    448
    QuestionWOT problem and P0300 - 2000 Eldorado
    I have a 2000 ELDO esc with about 68k. owned the car since new and have kept up with all the maintenance. This car has never given me any problems till now. Recently I was on a trip and about 200 miles into it the trip the misfire light started to flash , I was cruising at 75 to 80 mph. I slowed down to get over to the right lane and by the time I got there ther light went off, so I took it easy for a while . Twenty miles later same thing . I got to my destination checked as much as I could everthing looked ok and the car did not throw any codes or had any stored codes (had my scanner with me ). During the week I drove around with a mix of highway and rual driving no problems . A week later back on the road about 90 miles into the trip here we go again flashing light. The rest of the trip the light was going of and on, with no real interval schedule
    It seemed to be ok if I kept it at about 65 mph but that was no for sure cure . I got mad and started jamming the pedal down and it finally threw a p0300 (Random misfire). back at home in traffic and cruzin around car runs great . Sometimes when WOT from a dead start no problems . On highway when I WOT to pass the misfire light goes on but it quickly goes out . Any Ideas on this ? I got a trip comming up in about a month and I dont want to have any problems on the road. Sorry this is so long but these are the facts . Thanks in advance for any help you can offer.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,830
    Re: Wot problem
    Use the car's built in code reader/scanner system - it may show a history code that some handhelds won't.
    The sticky post ^^^ "How to pull codes". Use the directions for the OBD-II system in your 2000 (and later FWD) drivetrain. After you erite down all codes found, and whether each is Current or History, return to the sticky and open thelink with "obd2" in the address. This will take you to a Master Index of all P,B,C, and U code definitions. Write it all down and post it all here.
    FWIW, when the SES light flashes that's an indication of severe misfire and you run a very real risk of killing the catalytic converter from dumping raw fuel.
    Have you checked the FPR (Fuel Pressure Regulator) for a leaky diaphragm ? Under the beauty cover, rear driver's end of the fuel rail. Carefully pull the vacuum line connector off the nipple - any raw gas in there or in the line? If so, that's a prime suspect. Otherwise, you're in the ignition or vacuum leak diagnosis mode..............
    ELDO GUY's Avatar
    Sep 2004
    SKOKIE ,iLL
    66
    448
    Re: Wot problem
    Thanks !!! Im at work now but I will begin to look at this when I get home this evening . Ill report later .
    Feb 2006
    55,830
    Re: Wot problem
    Quote Originally Posted by ELDO GUY View Post
    Good..........Keep it all in this thread so we don't bounce around the Forum.
    If you get a break, pop a brew (at work ????) and go to Discussions, Item Specific; Cadillac Tech Tips and wade through as many pages as you can, looking for threads discussing "missing", "surging', "bucking'.......stuff like that: What you're after is intermittent codes that cause misfires and messages to appear.
    68
    81,883
    Re: Wot problem
    My guess is you are due for a set of plugs (A/C Delco 41-987). If that doesn't help, then it's probably a bad coil. The coils are in the ignition cassettes set into each of the cam covers. You'd have to determine which bank and then replace THAT cassette. The coils are not serviceable individually.
    ELDO GUY's Avatar
    Sep 2004
    SKOKIE ,iLL
    66
    448
    Re: Wot problem
    Got some update Info. I checked the FPR with a vacum tool and it held vacum .No evidence of gas either so I think Im good there . As far as retreiving codes from the cars system I think the Eldos buttons are different . The Info button has skip printed in yellow above it and the button only moves in and out the next button says info reset with (no) in yellow above it and the third button says trip reset with a yellow (yes)above it .The only information I get is by holding down the info reset button and info reset button at the same time Is (monitiored systems ok).
    I did leave some important info out in the inital post because it was getting long. The front coil cassette was replaced new about a year ago #4 was bad also replaced that plug at the same time with the proper ac delco plug . A few months ago replaced the rear cassette #5 was bad .I cheaped out and got a bone yard replacement that was about 10 years old and replaced the #5 plug with the proper ac delco plug. When I replaced the plugs they still looked good. Do the plugs need to be replaced before the 100k Tune Up . Any history on the life span of those cassete coils? Thanks for the help and Ideas . Beat me if necessary for cheaping out on that last cassette.
    68
    81,883
    Re: Wot problem
    Ignition cassettes are generally pretty reliable. I would not hesitate to use a junk yard cassette. Especially for that price.
    Unless a plug is misfiring it does not need replacing. Many times you can go well beyond 100K and many members have.
    As for the codes, I know the Eldo's did not get a lot of the upgrades since it was slated for extinction. I wonder if it might possibly still use the old Pre '98 Seville method as posted by N*caddy in this link. Scroll down to find it.
    http://www.cadillacforums.com/forums...odes-dtcs.html
    ELDO GUY's Avatar
    Sep 2004
    SKOKIE ,iLL
    66
    448
    Re: Wot problem
    I will look in to that . My 82 and 85 eldos had that capability and it worked well. Thanks for the info
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    49
    1,948
    Re: Wot problem
    If you're not getting a specific cylinder code, make sure the intake/airbox clamps are tight & look for cracks in the plastic by the thottle body.
    If you do need a new coil, http://www.amazon.com/Cadillac-Eldor.../dp/B0064J1ZT6
    Cheapest I've seen.
    ELDO GUY's Avatar
    Sep 2004
    SKOKIE ,iLL
    66
    448
    Re: Wot problem
    Thanks for the ideas. Last night I tightened the clamp.I think it was ok but gave it a little extra turn anyway. I also did the spray test and did not notice any rpm increase. I checked the Bolts on the plastic manifold and found a few to be a little on the lose side, not horrible but not as tight as the others. I also revisited my coil repairs and checked the connections to the ICM. and cleaned them with contact spray . Could a faulty ICM cause a issue like this ? If possible could someone explain to me the function of this part . I know it probably directs the current to the proper spark plug but does it do any thing more than that and its it able to be tested ? I went to test last night but it was raining here so I turned of the traction control to do a coulpe of WOTs. The tranny didnt not like that and the service transmission appeared in the DIC message and started to act funny so I Quit for the day .Thank God the message went away it appears that Trans is OK today ! Thanks for the continued help. This is a great place to be if your a Caddy guy.
    68
    81,883
    Re: Wot problem
    Check the ICM sticky near the top of this forum. While it is for the pre-2000, I suspect it works the same on the post 2000's.
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    Re: Wot problem
    yes, the eldo would be using the 99 and older deville dash or the 97 and older seville dash
    i have that same configuration ... holding down the red (warmer) button and the off button on the hvac panel will get you into diagnostics
    and i'd replace the plugs if you're anywhere near 100,000 miles (use only the acdelco oems ... ranger posted the part number in post #5)
    if you're still having problems then start looking at the coils packs (cassettes)
    ELDO GUY's Avatar
    Sep 2004
    SKOKIE ,iLL
    66
    448
    Re: Wot problem
    On my car their is no red button for the heat . The hvac is turned on by pushing in a knob. To increase the heat the knob is turned and the led numbers change up or down in relation to the direction the knob is turned or you can change it from the controls on the steering wheel ! Tx.
  16. #14
    Feb 2012
    NYC
    49
    1,948
    Re: Wot problem
    To get into yours, hold the "PAS^" & "OFF" between "mode" & "AC".
  17. #15
    ELDO GUY's Avatar
    Sep 2004
    SKOKIE ,iLL
    66
    448
    Re: Wot problem
    COOl ! Tx I knew there would be some way. With so many buttons many combos are possible. Just out of curisoity is the procedure listed in the FSM . It was in my 82 and 85 FSM's but i dont think I saw it in my 2000. but then there are about 700 more pages in the 2000 so i might have missed it !
  18. Remove Advertisements
