WOT problem and P0300 - 2000 Eldorado - Page 5
Page 5 of 5 FirstFirst 1 2 3 4 5
Results 61 to 69 of 69
Like Tree1Likes
Northstar Engines and System Technical Discussion Discussion, WOT problem and P0300 - 2000 Eldorado in Cadillac Engine Discussion; The ash covered one could cause a miss. Especially if there are more in the other bank. Could be caused ...
  1. #61
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    49
    1,948
    Re: Wot problem
    The ash covered one could cause a miss. Especially if there are more in the other bank. Could be caused by light oil burning.
    Here's a nice plug chart:
    http://www.fordtruckclub.net/forum/p...0/plugdiag.jpg
  2. #62
    ELDO GUY's Avatar
    ELDO GUY is offline Cadillac Owners Fanatic
    Automobile(s): 2K ELDO WHITE DIAM , 2K TURBO BUG ,69 VETTE ZZ4 2014 CTS
    Sep 2004
    SKOKIE ,iLL
    66
    449
    Re: Wot problem
    Going left to right I dont think the 3rd one looks so great either the 1 on the end is new only a few thousand. Could be the oil. I used a dose of MMO when I went on that last trip when the problem occurred . Mabe too old school of a product. I also plan on swapping out the icm on Bank one with one of the ones I have from my orginal coil packs .
  3. #63
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,909
    Re: Wot problem
    If you use MMO in the recommended mix ratio you'll never - never - see it on the plugs.
    The 3 mile and 1/4 mile trips are the problem - that engine never gets a chance to properly heat up. After only 3 miles your lube oil is still stone cold!
    From those plugs, even with the short hop driving your engine doesn't use much oil, does it ?? Short hops - about 12 - 14 mpg long term fuel average ??
  5. #64
    ELDO GUY's Avatar
    Sep 2004
    SKOKIE ,iLL
    66
    449
    Re: Wot problem
    Ya, your right on on the mileage and oil use . Hwy I get about 26 to28 but I have gotten as high as 31.2. It depends if I Am driving reasonably or If Im in a Hurry .
  6. #65
    ELDO GUY's Avatar
    Sep 2004
    SKOKIE ,iLL
    66
    449
    Ok here are the pics of bank 2. All were ok except for #8 it. Looked wet so to paper towel an. Extracted a microscopic point of water. It had no color to it but it was disturbing now I'm thinking the dreaded hg problem.. Had no hg related issues.
  7. #66
    Feb 2012
    NYC
    49
    1,948
    Re: WOT problem and P0300 - 2000 Eldorado
    That looks like a "miss". Was the wetness antifreeze, fuel or water? Could have been wet from the miss.
    I was under the impression that you checked the plugs when you did the coil.
  8. #67
    ELDO GUY's Avatar
    Sep 2004
    SKOKIE ,iLL
    66
    449
    Im pretty sure it, was water, but it wasnt orange color. Its been real damp and foggy here for what its worth. I only checked them. I only changed the offending. Iplug when i changed. The. Cassette.
  9. #68
    ELDO GUY's Avatar
    Sep 2004
    SKOKIE ,iLL
    66
    449
    Im down to my last idea . Back in the day I had a 68 dodge polara with a 383. I took it out, got about 10 miles from the house and it died right in traffic. I was all dressed up and called for a back up ride. Next day. I went to work on it bang started right up. Barely got home died again checked the spark. No spark . Got a new coil when Iwent to put it I checked again and it worked. When the coil got hot it died. Im thinking this is the same . I got a friend who has a new cassette that he will let me borrow . I bet its that old one I bought a few months ago (11 years old ). Im on it again tonight . last time.
  10. #69
    ELDO GUY's Avatar
    Sep 2004
    SKOKIE ,iLL
    66
    449
    Put in the borrowed coil cassette , Every thing seems to be fine I wonder if this was some sort of Intermintenent problem with the Icm . Ill test over the next few days to be sure Im done with this . Thanks again for everybodys input, time and ideas on this.
  11. Remove Advertisements
