WOT problem and P0300 - 2000 Eldorado - Page 4
Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 46 to 60 of 69
Like Tree1Likes
Northstar Engines and System Technical Discussion Discussion, WOT problem and P0300 - 2000 Eldorado in Cadillac Engine Discussion; Yes about a month or two before It showed up 2 or 3 times but went away . I contributed ...
  1. #46
    ELDO GUY's Avatar
    ELDO GUY is offline Cadillac Owners Fanatic
    Automobile(s): 2K ELDO WHITE DIAM , 2K TURBO BUG ,69 VETTE ZZ4 2014 CTS
    Sep 2004
    SKOKIE ,iLL
    66
    446
    Re: WOT problem and P0300 - 2000 Eldorado
    Yes about a month or two before It showed up 2 or 3 times but went away . I contributed it to the oil flying all over the place . Any possibility of Icm issue. When I replaced the last cassette that was ten years old I was in a hurry and never pulled the icm out and cleaned it up. Also as a side note my car used to idle so well that often times you would not know that it was running. Now it seems less smooth. Also any possibility of a maf issue? I just cleaned that thing up a while back.
  2. #47
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,566
    Re: Wot problem
    ANY air leak at or after a divorced MAF will cause a lousy idle, maybe set mixture codes, and contribute to a midrange acceleration stumble.
    Post a picture of YOUR intake system, and if yours has a resonator on the duct, with that removed...........reference.........
    Click on my username, get to my profile - open the two albums - 6 pages - for pics and illustrations of the 2000+ Seville intake system with the resonator removed..............
  3. #48
    ELDO GUY's Avatar
    Sep 2004
    SKOKIE ,iLL
    66
    446
    The only consistant thing is that in the high rpm range it starts missing then after a while it goes away with no codes . I did get the po340 a few times a month or 2 ago but I contributed that to the oil being thrown all over the place when I left the filler cap off before I went on a trip. When I replaced the 10 year old coil cassette . I didnt remove and clean up the icm. is that a possible issue? Also I recently cleaned up the maf sensor and cleaned up my k&n filter. Sorry for the delay in response but we had some weather issues here and I took on some water in my den!
    Sorry kind of double posted on that last one! Up to late cleaning up water .
  4. #49
    68
    81,755
    Might try getting rid of that K&N, clean the TB and go back to the factory air filter.
  5. #50
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    49
    1,948
    No resonator on the duct in the Eldos. MAF is near air filter. You said clamps are tight. Check carefully for cracks in the duct between MAF and TB.
  6. #51
    ELDO GUY's Avatar
    Sep 2004
    SKOKIE ,iLL
    66
    446
    Will do . Im on this thing tommrow. Im gonna change out the cpk . Test , if this is no good then pull out the icm on the old replacement unit clean and replace it with one of my other ones. also gonna check plugs and the ground on the coil packs. After that ? I can see that cpk thing done in aout a half hour. if it goes well or all day if dont ! Could possibly require a few "beverages".
  7. #52
    68
    81,755
    Quote Originally Posted by ELDO GUY View Post
    you do realize that there are 2 of them, don't you?
  8. #53
    Feb 2012
    NYC
    49
    1,948
    If CPK means CMP (cam sensor), there is only one. There are 2 crank sensors..
  9. #54
    ELDO GUY's Avatar
    Sep 2004
    SKOKIE ,iLL
    66
    446
    I was up too late cleaning up water . Im changing the cam shaft sensor! TX.
  10. #55
    68
    81,755
    CKP = Crankshaft Position sensor
    CMP = Camshaft Position sensor
  11. #56
    Feb 2006
    55,566
    For an instant, positive performance improvement get rid of the aftermarket cotton filter and install a real high flow air filter: Purolator, AC Delco, Fram, WIX, PartsMaster.
  12. #57
    ELDO GUY's Avatar
    Sep 2004
    SKOKIE ,iLL
    66
    446
    Up date. I changed the cmp. That had to be the worst thing ive ever done . Aztec thanks for the insight on how to do this. Did not solve my problem so I went to plan B . I removed the Coil cassette from Bank1 and removed all the plugs .Two of the plugs didnt look so Good .I will post picture of bank 1 plugs later Plan now is to replace all the plugs . Ran out of time this week end
  13. #58
    ELDO GUY's Avatar
    Sep 2004
    SKOKIE ,iLL
    66
    446
    Here are the 4 plugs i removed. My driving history is 3 miles daily to work one way and a1/4 mile drive to ymca for lunch work out. Every 6 to 8 weeks about 600 mile round trip at high speed, to my condo in door county wis. Iwas thinking that maby i should bump up the heat range of the plug if that was available. Im a WOT addict so this happens a few times a week naturally.
  14. #59
    Feb 2006
    55,566
    Re: Wot problem
    The present heat range is OK and those 4 plugs look just fine.
    The plug on the left is covered with ash from a sudden high speed acceleration - after your 600 mile trips all 4 of those plugs would look sort of light brownish-white with maybe a flake or two of ash........about like the second plug from the left.
    The discolored oil stains on the body are from the normal plug well O-ring seal weeps.
    Your engine takes AC Delco (DENSO) #41-987 plugs which come pregapped to .050".
  15. #60
    ELDO GUY's Avatar
    Sep 2004
    SKOKIE ,iLL
    66
    446
    Re: Wot problem
    Gonna change all the plugs tonight . Report back tommrow. Im out of Ideas after this so Ill probably have to take it in if it dosent work. Any other Ideas out there ? Tx for all the imput so far .
  16. Remove Advertisements
