WOT problem and P0300 - 2000 Eldorado - Page 2
Page 2 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 16 to 30 of 69
Like Tree1Likes
Northstar Engines and System Technical Discussion Discussion, WOT problem and P0300 - 2000 Eldorado in Cadillac Engine Discussion; I think it is in there somewhere....
  1. #16
    68
    81,916
    Re: Wot problem
  2. #17
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    Re: Wot problem
    ah, you have the ETC model without the digital dash (with gauges)
  3. #18
    ELDO GUY's Avatar
    ELDO GUY is offline Cadillac Owners Fanatic
    Automobile(s): 2K ELDO WHITE DIAM , 2K TURBO BUG ,69 VETTE ZZ4 2014 CTS
    Sep 2004
    SKOKIE ,iLL
    66
    449
    Re: Wot problem
    Took a sneak out to the car during work . Axtec Tx. for the keys to the Kingdom. Yikes ! What is all this stuff. P0731 I sure this was the results me trying to do WOTs and turning off the traction control while I was still moving. Not recommended ! U1152, B1327,B1771 U1255, U1000,B2119. Can this info be found in the FSM cause Im still at work for awhile. All was stored in history. When the codes stopped spitting out it stopped at PCM? What would the next action to be taken from this point. Also can I remove these codes some how? Tx.
  5. #19
    Sep 2007
    Wilmington, NC
    13,986
    Re: Wot problem
    first take a step back and breathe... lots of codes is common... what you need to do is figure out what they all meanin the sticky thread there's a link to the obd1 and obd2 code definitions ... (your car is obviously obd2 so use that link)also note which codes are current and which are history ... there will be a C or an H at the end of the codes to designate this aspectthen come back and post up the codes (noting history or current) AND their definitions then we'll be getting somewheregood luck
    remember the easiest way to exit diagnostics is to just turn the key back to off and take it out of the ignition
  6. #20
    68
    81,916
    Re: Wot problem
    Yes, the DTC sticky Rippy mentione will explain it, but if they are current, they will return as soon as the failure is detected again.
  7. #21
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    49
    1,948
    Re: Wot problem
    P0731- Incorrect 1st gear ratio. Could be a bad sensor or a slipping trans. Good news is no misfire codes. B1327 is a low voltage code which could cause your other problems.
    To clear PCM codes, go into Diag mode, press "FAN DOWN" to display "PCM?". Press "FAN UP". Press "FAN DOWN" to show "PCM CLEAR CODES". Then press "FAN UP". PCM codes cleared. The PCM codes are the only ones that will put the light on.
    Recirc button will get you out of diag without turning key off.
  8. #22
    ELDO GUY's Avatar
    Sep 2004
    SKOKIE ,iLL
    66
    449
    Re: Wot problem
    Thanks for the further info . Did some Wot testing to day . Went on the highway on the way to costco no problem . On the way back did a few more WOTS then ,flashing light, pulled off and left iginiton and pulled codes nothing. light went off. went a mile or so further then flashing light again. I was of hwy by now so i did codes as I was driving . NOW I gOT A p0300 CURRENT . So at least there something. This problem seemes to arrise during extended HWY especially in the over 65 mph and up driving and WOT or passing situations, around town I good. . Anybody got ideas for a strating point . Ill check that voltage thing later on today. just changed the serpetine belt last week so that could be a carry over issue .The belt was the orginal.
    Forgot . CEL is not on . only stored in current mode. TX
  9. #23
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,881
    Re: Wot problem
    P0300 C - Misfire detected. (The address for "obd2" in the code pull sticky. Master Index)
    How old/miles are your spark plugs ?? ACDelco #41-987 plugs. Maybe a set of boots.
    Click on my username, open the profile. 2 albums in the left column, 6 pages of your engine and parts and procedures - most annotated. You're gonna love changing the plugs............also, check your fuel injector electrical connectors and all the intake duct clamps at and after the MAF - one loose clamp will set codes and cause rough idle/stumble.
  10. #24
    Feb 2012
    NYC
    49
    1,948
    Re: Wot problem
    This just in! Same thing happened to my car today. Blinking light, P0300 with NO MISS. Took a while and a few clearings but finally threw a P0340, CAM SENSOR. It's on the front of the rear head. Damn near need boneless hands to change it. It's good now.
    Try it only if you're not feeling a miss.
    I guess it could also lead to the P0731 that you had too.
  11. #25
    ELDO GUY's Avatar
    Sep 2004
    SKOKIE ,iLL
    66
    449
    Re: Wot problem
    Ill answer both you and sub here . Plugs are orginal except for # 4 and #5 that I changed out when I did the coil packs . Plugs with 68k miles. Replaced plugs with correct A-C plugs although orginal plugs in car were not AC. They were denso 12561446 the is also another# on the plug pt16epr-c13. I bought this car new so no one should of changed these they look just like the A-C s.
    Aztec HMMMMMMM ! A couple of months previous to this miss thing I got the P0340 a few times but It went away. I attributed to the fact that I took a trip and forgot to put the oil filler cap on and was really driving hard and oil was thrown all over the engine . I cleaned every thing up and it went away. I have a miss though but it is not present all the time just when get the flashing light.
  12. #26
    Feb 2012
    NYC
    49
    1,948
    Re: Wot problem
    That's it. You have an intermittently shorting Cam sensor. As long as you're not feeling a miss, that is. It is a ball buster to change. Maybe easier with hoses removed. I snuck mine out & in. This was the first one I had to change in a Cadi. Good luck!
    If you had a bad coil or plug, you should be getting a specific cylinder code.
  13. #27
    Feb 2006
    55,881
    Re: Wot problem
    Quote Originally Posted by ELDO GUY View Post
    . Plugs are orginal except for # 4 and #5 that I changed out when I did the coil packs . Plugs with 68k miles. Replaced plugs with correct A-C plugs although orginal plugs in car were not AC. They were DENSO 12561446 the is also another# on the plug pt16epr-c13.
    The original plugs in most of these engines were DENSO - the new "AC Delco" plugs are made in Japan by DENSO - look at the box. Somewhere along the line - maybe 2002 or 2003 - the plugs started to be installed with the new contract AC marking system. My 2002 owner's manual still listed the DENSO plug number.
    FWIW, when you get the steady SES light you have some occasional engine miss or emissions problem - when the light begins flashing you have a reoccurring or steady miss and you run the real chance of cooking the catalytic converter by dumping excess raw fuel into it.
    Just for grins, also test the FPR while you're in there changing the CMP.
  14. #28
    ELDO GUY's Avatar
    Sep 2004
    SKOKIE ,iLL
    66
    449
    Re: WOT problem and P0300 - 2000 Eldorado
    So consensus is to change the cmp . How long did that take ! Ill look in the fsm for the procedure and exact location. Ive heard this is pretty ugly and involves lots of swearing . Any recommended brand to use for this . I did check the fpr with a vacum checker and it did hold pressure. Tx.
  15. #29
    ELDO GUY's Avatar
    Sep 2004
    SKOKIE ,iLL
    66
    449
    Ok guys , Two more questions . Where is the CMP. I'm looking on the passenger side by all the heater hoses on the block, on width side . And when I find it . How do I attack this thing. from top or bottom ? I looked in the FSM but its not real informative TX.
  16. #30
    Feb 2012
    NYC
    49
    1,948
    It is on the front of the rear head, right where you're looking. Below the hoses. Tough to see, even harder to change. It took me about a half hour from the top using a 1/4" air ratchet, a short 10mm socket and a couple sets of long needle nose pliers. I cut a small piece of the new shield off and used a shorter bolt with a "starter" point on it to make it easier. There's really no good way to talk you through it. I've been workin' on cars for about 30 years and it gave me a hard time. It's a three, small, boneless handed job.
    I just got one from my parts store that I deal with everyday.
  17. Remove Advertisements
