Where is the oil level sensor located?
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, Where is the oil level sensor located? in Cadillac Engine Discussion; Check oil level sensor may be bad as sometimes when I turn the car to on, a message is displayed ...
    carguy is offline Cadillac Owners Member
    May 2004
    Florida
    44
    Check oil level sensor may be bad as sometimes when I turn the car to on, a message is displayed on the DIC. I assume that it is on the pan somewhere, I haven't looked yet. I just wanted to ask those that may know first, and make it easier for me.
    Thanks
    sts96 is offline Cadillac Owners Fanatic
    May 2004
    333
    Re: Where is the oil level sensor located?
    On my 96 its on the front upper just to the right pass.side of center of the oil pan tight fit but can be changed. lol sts96
    Pjs's Avatar
    Pjs
    Pjs is offline Cadillac Owners Fanatic
    Mar 2004
    Nashville, TN
    367
    Here is a pic of the float level switch where it goes through the right left side (if your looking down @ the oil pan) Sorry the windage tray is covering the end of the float
