Hard starting.
Page 1 of 2 12 LastLast
Results 1 to 15 of 25
Northstar Engines and System Technical Discussion Discussion, Hard starting. in Cadillac Engine Discussion; I have a 96 ETC. The car starts hard (takes quite a few cranks of the starter), and then has ...
    carguy is offline Cadillac Owners Member
    May 2004
    Florida
    44
    Hard starting.
    I have a 96 ETC. The car starts hard (takes quite a few cranks of the starter), and then has a rough and fluctuating idle, and hesitates. After the vehicle warms up it runs fine, but on shutdown starts hard again.
    Plug wires, plugs, fuel filter have been recently replaced. I haven't checked anything as yet, ie codes or fuel pressure.
    Any ideas?
    Feb 2004
    FL
    2,250
    Re: Hard starting.
    Check FPR for leaks at the vacuum hose, and check the fuel pressure key on, engine off (after fuel pump primes). It should hold steady around 40psi or so, and not drop a significant amount in any time.
    May 2004
    Florida
    44
    Re: Hard starting.
    It may be this or the pump. I removed the beauty cover and pressed on the schrader valve just after the engine was shut off after starting and barely any fuel came out. I will run the fuel pressure test tonight. The car has about 71,500 miles on it.
    Thanks.
    96 STS's Avatar
    96 STS is offline Cadillac Owners Fanatic
    Automobile(s): 1996 Seville STS, 2002 Seville SLS
    Nov 2003
    Long Beach, MS
    49
    132
    Re: Hard starting.
    Hi carguy! Just my .02 cents, but like eldorado1 mentioned, check to make sure that your pump is priming the system when you first turn the key. Should run for 2 seconds to prime the system for startup, then shut off. You should be able to hear this if your car is parked in a pretty quiet area, like a garage or no traffic or other noise around you.
    As my name implies, I've got a '96 Seville & had the same experience this weekend. My car started up fine in the garage but went dead right after I pulled out. Luckily it happened there & not out on the road.
    I did the same thing with the schrader valve & got the same results. I'd suggest what I read here on the forum & kind of trace the system back. Meaning if you get no fuel at the valve, then disconnect the fuel line at the filter & see if any pumps out there. Could be a clogged filter. If nothing pumps out before the filter then it probably IS the pump relay or the pump.
    As I learned thru my service manual, the PCM is programmed to prime for 2 seconds then will not start the pump again until sufficient ignition parameters are met. I assume this means that the engine is running. Because of this I found it kind of hard to verify if power WAS going to the pump or not. Of course I did my repair by myself. Perhaps you could get someone to help you to verify if power is getting to the pump during this 2 second prime time. On mine you could access the pumps electrical plug under the car just behind the tank.
    I don't know if an ETC tank & pump are the same as a Seville, but if they are I have a bit of advise from my repair experience this weekend.
    If you have to drop the tank to get to the pump, you DON'T have to remove the filler pipes or completely remove the tank. I was able to get access to my pump by simply putting the car on stands as high as I could (all 4 corners), then unbolting the the 4 tank support bolts & dropping the front of the tank while supporting the rear of the tank with blocks (or something so as not to strain the filler pipes). I then had more than enough room/clearance to remove the pump.
    Somehow mine ended up having shorted/fused wires with the fuel level sender. It all made since when I found it because my fuel gauge had been acting crazy for a few months (1 second it said empty, the next second is said 1/2 tank). I ended up deciding to just repair the wiring & reinstall the pump. So far so good. I'm still a bit curious & worried about what fused these wires together to begin with, but I don't really have the $$$'s right now for a new pump. So I took a chance & repaired the pump & reinstalled.
    Again, if you think you'll need to remove your pump & the ETC is the same tank setup as a Seville, don't worry about disconnecting the filler pipes. Trust me, it's a B*tch!! I DID have to once in order to gain clearance to replace some brake pipes & hope that I never have to do that again.
    Anyway, good luck with your situation & keep us posted.
    Cheers,
    96 STS
    mcowden is offline Cadillac Owners Connoisseur
    Jun 2003
    1,164
    Re: Hard starting.
    That's great info, STS96, thanks very much for posting... I'm headed down the troubleshooting path that's leading closer and closer to the pump on my 96 SLS, so this may save me significant time and effort very soon. Appreciate the heads-up! I'm stumped as to what caused your short. Maybe corrosion and some arcing? Without having seen the harness going into the tank I couldn't speculate inside the ballpark...
    Mike
    May 2004
    Florida
    44
    Re: Hard starting.
    My starting problem is intermittent. Starts fine in the morning after it has sat overnight.
    I checked the FP
    It was 45 psi at prime and 45 psi running. However, the vehicle was starting fine at the time so I am going to try it again today when I think it will have it's problem. I will report back on here today.
    Oh, and as I stated above I just recently replaced the filter. The old one was in good shape too (not plugged)
    May 2004
    Florida
    44
    Re: Hard starting.
    I just checked it again and was starting hard. The fuel pressure was the same as above and went over 50 psi with the vacuum line to the regulator disconnected.
    I don't think the engine was flooded so it may now be an ignition problem.
    Crank position sensor? cam position sensor?
    Any other ideas?
    69
    82,286
    Re: Hard starting.
    Hard hot starts usually indicate a rich condition. Leaking FPR or injector(s).
    May 2004
    Florida
    44
    Re: Hard starting.
    I will look into that. Wouldn't that also cause a drivability issue too?
    Feb 2004
    FL
    2,250
    Re: Hard starting.
    Okay, when it primed the fuel pump, and went to 45psi, did it start dropping quickly? Or did it stay at roughly 45psi for a good 10 minutes or more? Just from the initial prime, I can stay above 40psi for 20 minutes to a half hour.
    69
    82,286
    Re: Hard starting.
    Quote Originally Posted by carguy
    I think it might depend on how bad it is leaking. Might not be noticable.
    May 2004
    Florida
    44
    Re: Hard starting.
    I will check to see how long the pressure stays up, but I don't think that this is it. At start there is plenty of pressure either way.
    I forgot to mention that the car also backfires through the intake sometimes, ONLY WHEN TRYING TO START.
    I am now suspecting an electrical issue, such as a crank or cam sensor.
    I checked the codes and there is only one, which is a History code.
    May 2004
    Florida
    44
    Re: Hard starting.
    Fuel pressure stays up for quite some time...
    Fuel injectors are not pulsing during cranking.
    Cam position sensor??
  16. #14
    May 2004
    Florida
    44
    Re: Hard starting.
    Hmmmm..where is the cam sensor. I looked over all the covers and didn't see any wires going in any. Is everything under the cam cover? Do I have to take it off to access the sensor?
  17. #15
    Feb 2004
    FL
    2,250
    Re: Hard starting.
    Passenger side, front (as in pulley-side) of the *rear* head. Don't have to take anything off afaik... You *might* have to go in through the passenger wheel well, not sure how much clearance you have from up top.
  18. Remove Advertisements
