northstar studs
Results 1 to 10 of 10
Like Tree1Likes
  • 2 Post By Submariner409
Northstar Engines and System Technical Discussion Discussion, northstar studs in Cadillac Engine Discussion; Im aware of supply issues with a certin company making studs but is anyone else making a set? I took ...
    lx2gt is offline Cadillac Owners Member
    Automobile(s): benz tech, side job city
    Apr 2012
    1
    northstar studs
    Im aware of supply issues with a certin company making studs but is anyone else making a set? I took on a head gasket job as a favor for an elderly man with little money and didnt expect parts supply to be an issue. Id rather stud it than inserts but i figured id give it a shot before going with inserts. Any help is greatly appreciated. Sooner the better as the old man rented a car because i said i could get it done in a week.
    Thanks!
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,873
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,191
    Re: northstar studs
    Don't discount inserts and a new set of head bolts OR studs out-of-hand. If you're in a bind, talk to both Norm Huhn at www.huhnsolutions.com and Tim Carroll at CarrollCustomCadillac.
    Yes, studs are the most elegant solution, but again, don't discount a healthy insert job.
    Faded Crest and Faded Crest like this.
    vincentm's Avatar
    Aug 2010
    Kennewick WA
    38
    4,873
    Quote Originally Posted by submariner409 View Post
    ThumperPup's Avatar
    ThumperPup is offline Cadillac Owners Master
    Automobile(s): not anymore 2007 Lexus ES350
    Mar 2009
    Murray/ Snowbird Utah
    37
    7,696
    Re: northstar studs
    i had norm sirts in for 23k before my blocked cracked
    they did not seem to have any problems
    but i decided the next time around when i got it done 6 months latter from the cracked block i wanted it studded
    Feb 2006
    56,191
    Re: northstar studs
    Why ? What is the mechanical difference between studs and NS300 inserts ?
    dwillv is offline Cadillac Owners Member
    Automobile(s): deville
    Nov 2011
    43
    Re: northstar studs
    im still waiting for my kit. 5 months later. there was another guy offering machined studs.check n old thred
    89falcon is offline Cadillac Owners Fanatic
    Automobile(s): my wife crazy, 1997 STS, 2004 CTS
    Apr 2011
    188
    Re: northstar studs
    Sub, be kind when you slam me for my reply.....but:
    I think the one major advantage of studs is that they are being mostly pulled when being torqued, while serts seems to have more of a twisting load when used with stock bolts.
    I will admit that I have one concern WRT studs.....there doesn't seem to be the level of engineering in them that was put into the stock bolts....ie, how much do they stretch? How much do the expand and lengthen when heated? Do they keep the ideal clamping load on the head gaskets when they go thru a heat cycle?
    On the issue of cracks after the repair......if you make the hole bigger, the amount of aluminum around the bolt will obviously be less....and leads to a higher chance of cracks.......makes sense to me!
    ThumperPup's Avatar
    Mar 2009
    37
    7,696
    Re: northstar studs
    Not sure why just wanted it i heard so many good things everyone was saying studs are the way to go
    the Block was ordered new from Jake he shipped it to David at PowerTrain Automotive along with the studs
    so i figured id give Jake the business he was really good on the price also
    i am not sure if david even marked up the price on the block at all i think he did the parts at cost i know the block was like 500 is what i paid
    for a brand new never used Northstar Block from an 02 casting
    68
    82,056
    Re: northstar studs
    NS300L inserts will do the job just as well as studs will.
  13. Remove Advertisements
