18mm Northstar Crankbolt needed
Results 1 to 4 of 4
Northstar Engines and System Technical Discussion Discussion, 18mm Northstar Crankbolt needed in Cadillac Engine Discussion; In rebuilding my 97 STS N* engine I bought a crankshaft off ebay. The crankshaft did not come with a ...
    ToMuchWork is offline Cadillac Owners Member
    Automobile(s): 97 sts
    Oct 2009
    24
    In rebuilding my 97 STS N* engine I bought a crankshaft off ebay. The crankshaft did not come with a crankshaft bolt and my original bolt is too small for this crankshaft. Seems that there are crankshafts that have 14mm bolts and ones that have 18mm bolts. I have called all the GM dealerships in my area but all the bigger bolts that they have are about 3 inches longer then my original bolt. Anyone know where I can find a new 18mm crankshaft bolt? I would like to get a new one as I understand they have to have quit a bit of torgue on them and dont want to risk using one that has already been stressed. Any help very much appreciated.
    Thanks,
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,872
    Re: 18mm Northstar Crankbolt needed
    Fastenal?
    Oct 2009
    24
    Seems like the N* came with either a 14mm or a 18mm crankshaft bolt for a number of years. Anyone have a idea why? This N* engine just keeps on throwing out curveballs.
    tateos's Avatar
    tateos is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 ETC (GAVE TO STEPSON 2011), 2000 DTS (RIP)
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,704
    The original bolt, unless abused, may be re-used - there is not that much torque applied to it when installed - it's just hard to break free when trying to remove it after many years of being installed. That said, I buggered up the head on my bolt in the removal process - through carelessness, really - ordered a replacement from gmpartsdirect.com
  7. Remove Advertisements
