Bent pushrod - valvetrain noise ?
Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Like Tree3Likes
Northstar Engines and System Technical Discussion Discussion, Bent pushrod - valvetrain noise ? in Cadillac Engine Discussion; I have 205k miles on my 97 sts and I believe I had the unfourtantly event of getting a bent ...
    Sparkyy's Avatar
    Sparkyy is offline Cadillac Owners Member
    Automobile(s): 1997 Cadillac STS, 69 Dodge Super Bee, 97 Mustang GT
    Nov 2011
    Montpelier, VA
    27
    38
    I have 205k miles on my 97 sts and I believe I had the unfourtantly event of getting a bent pushrod on the ride home from work after passing someone? Is there any quick fixes and what's the life expectancy of the motor now. I drive easily but I do drive it for sure sometimes
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,263
    Re: Bent pushrod.
    It's a pretty neat trick to bend a pushrod in a DOHC motor that doesn't have them.
    Don't mess with Binky Bear!
    Sparkyy's Avatar
    Nov 2011
    Montpelier, VA
    27
    38
    I have a nice knocking noise coming from one if the heads, any idea what it might be. It was a little low on oil and I added a quart but I do that once a week as it is
    69
    82,155
    Re: Bent pushrod.
    Broken valve spring?
    dkozloski and dkozloski like this.
    Sparkyy's Avatar
    Nov 2011
    Montpelier, VA
    27
    38
    Yes I believe that's what it is now, I'm having the car looked at today to find out and thank yall
    Faded Crest's Avatar
    Faded Crest is offline Cadillac Owners Connoisseur
    Automobile(s): '66 SDV, '76 CDV, '89 BRM, '92 BRM, '98 Concours, '00 SDV
    Apr 2008
    North Carolina
    45
    3,222
    Re: Bent pushrod.
    I also heard of someone having a broken cam bolt on their N*, but broken valve spring is more likely.
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    50
    1,948
    Re: Bent pushrod.
    I think if a valve spring broke, it would have sucked a valve & BLEW UP. Could be broken cam bolt. Or just plain worn out at 205K. Wrist pin knock? Sometimes hard to pinpoint noise.
    johnny kannapo's Avatar
    johnny kannapo is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 Eldorado
    Oct 2009
    Pigseye, Mn
    56
    2,814
    Re: Bent pushrod.
    Most likely would be cam lobe wear due to a failed valve bucket contact surface.
    mike5514 is offline Cadillac Owners Enthusiast
    Automobile(s): 97sls,09dts
    79
    878
    Re: Bent pushrod.
    I had a tapping noise on my 97 turned into a knock put in a blue 16 oz. bottle of a zinc additive tap/knock gone. Worth a shot couple of bucks.Mike
    Oct 2009
    Pigseye, Mn
    56
    2,814
    Re: Bent pushrod.
    Maybe so, if there is a tapping in this engine I would have a hard time believing a bottle of zddp is going to help.
    Nothing can get stuck in the valve train unless a valve was stuck in a guide.
    Stuck guides would have a difficult time getting oil to then.
    I don't think anyone here has ever posted stuck valve problem in this forum.
    I suppose that could happen but it would run rough & pop out the exhaust or intake which would blow off the back fire valve.
    If you know where in the head the noise is, to check for piston/rod problem pull a plug wires to see if the noise lessens.
    If the noise is on the Trans end of the engine It could be associated with the Trans. Flex plate for example maybe coming apart.
    It can be tricky pin pointing knocks.
    79
    878
    Re: Bent pushrod.
    Don't remember how long ago I added zddp but I went out yesterday the 97 has been sitting for about a week and I opened the hood started the car got back out and listened to the engine no tap no knock just typical N coming off fast idle.
    The other day I picked up some Quaker State Defy 5 quart big letters on the jug zddp added for high mileage engines. Leads me to believe the removal of zddp is/or was not a gov./epa. thing it was the oil companies that decided to remove it. If Quaker State feels there might be a market for it there might be something to it.
    My dts has 90000 miles on it and I think I will be using the QS with my next oil change. I haven't used QS in years I have been using Havoline/Chevron but if the new QS keeps my Ns from ticking or knocking it might be a keeper.Mike
    naif is offline Cadillac Owners Connoisseur
    Automobile(s): 1999 Seville STS, 2004 Deville DHS
    Mar 2011
    near Virginia Beach, VA
    1,277
    Re: Bent pushrod.
    ZDDP was removed because it can poison catalytic converters if there's enough oil burned - making the cost of the required 100,000 mile (in some places) emissions warranty worth the added expense of designing in no high-sliding-friction areas (flat tappets).
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,554
    Re: Bent pushrod.
    mike, take a look at the oils and spec sheets from Shell and Pennzoil also - in addition to Quaker State they're refined and packaged by the same company - SOPUS (Shell Oil Products U. S.)
    Yes, excessive ZDDP will ruin a cat, but ZDDP has not been removed from starburst oils used in automobile engines - it has been reduced in percentage by volume. Ranger recently posted a table of ZDDP levels for the last ?? 20 ?? years of oil API specifications - from SF to SM, I believe.
    Because ZDDP contains phosphorus and zinc, the EPA is the driving force behind its reduction in motor oils - same reasons why phosphorus is being phased out of dishwasher and laundry detergents: California's (and, by default, Big Brother's) fear of excessive human ingestion of perceived nasties.
    If SF and SG oils were perfectly fine for catalytic converters ~15 years ago, they would be just fine right now.
    Here's one reference of hundreds - Google "api oil service designation".
    http://en.wikipedia.org/wiki/Motor_oil
  16. #14
    Mar 2011
    1,277
    Re: Bent pushrod.
    15 years ago there wasn't such long required warranties on emissions...
    Yes, I meant to say reduced, not sure how it came out as removed
  17. #15
    Feb 2006
    56,554
    Re: Bent pushrod - valvetrain noise ?
    Yeah, that ^^^^
    I'm gonna move this thread to Northstar and give the engine gearheads a shot at diagnosis -
  18. Remove Advertisements
