Towing in third gear
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, Towing in third gear in Cadillac Engine Discussion; What's the recommended top speed/rpms in third gear while towing? I know cars were geared different in the past....
    jrb03deville is offline Cadillac Owners Member
    Jan 2012
    25
    69
    82,173
    Re: Towing in third gear
    I don't think there is a "recommended" top. You'll be at a 1:1 gear ratio so the RPM's will be higher, but nothing out of line or detrimental at highway speeds.
    CadillacLuke24's Avatar
    CadillacLuke24 is offline Cadillac Owners Master
    Automobile(s): Alexandra - 96 SDV --- Clyde - 15 Silverado
    Jul 2010
    Wyoming
    26
    5,759
    The manual says 3rd gear, so you'll be good. The idea is that you get more power and torque than in overdrive. Your year manual (2003) says to pop it in third when you're approaching a long or steep grade, in order to keep your brakes from failing. It also says to reduce speed to 45-50 mph, as well as keeping the car out of 2nd gear, and RPM below 3800. Furthermore, if you're climbing a 4%+ grade or a grade in 90+ degree heat, your cooling system may struggle to perform well enough to keep the engine cool.
    Basically, don't drive like a teenager and you'll be good. Drive like a GRANDMA!
