N* Upper to Lower block half sealing procedure.
Results 1 to 4 of 4
Northstar Engines and System Technical Discussion Discussion, N* Upper to Lower block half sealing procedure. in Cadillac Engine Discussion; Anyone know if the procedure below is still the current procedure to seal the upper and lower block halfs of ...
    ToMuchWork is offline Cadillac Owners Member
    Automobile(s): 97 sts
    Oct 2009
    24
    Anyone know if the procedure below is still the current procedure to seal the upper and lower block halfs of a N* engine?
    Thanks,
    http://www.cadillacforums.com/forums...v-sealant.html
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,191
    Re: N* Upper to Lower block half sealing procedure.
    That's it.
    Oct 2009
    24
    submariner409,
    Thanks for the info. I assume that the original rubber gasket comes out of the groove in the upper block half and is thrown away and not reused. The groove is then filled with the sealant. Just want to confirm this.
    Just one last thing. With the new cartridge type crankshaft rear main seal do you still need to put sealant in the housing as mentioned below.
    Feb 2006
    56,191
    The original halfcase silicone seal is not used.
    I have not done the new cartridge, so will have to duck that question - ask AJXTCMAN, Joe Tahoe or Jake.
  7. Remove Advertisements
