98 ETC Head Gasket project started today... - Page 9
Page 9 of 18 FirstFirst 123456789101112131415161718 LastLast
Results 121 to 135 of 267
Like Tree51Likes
Northstar Engines and System Technical Discussion Discussion, 98 ETC Head Gasket project started today... in Cadillac Engine Discussion; Originally Posted by JoeTahoe use a razor blade and a shop vac for the heavy carbon, Than try carb cleaner ...
  1. #121
    Faded Crest's Avatar
    Faded Crest is offline Cadillac Owners Connoisseur
    Automobile(s): '66 SDV, '76 CDV, '76 FWB, '78 CDV, '89 BRM, '91 BRM '92 BRM, '98 Concours, '00 SDV
    Apr 2008
    North Carolina
    45
    3,183
    Re: 98 ETC Head Gasket project started today...
    Quote Originally Posted by JoeTahoe View Post
    use a razor blade and a shop vac for the heavy carbon, Than try carb cleaner on a rag
    Thank you Joe. I actually started to do that but figured I'd better make sure it wouldn't hurt anything since it might scratch the surface a little.
  2. #122
    JoeTahoe is offline Cadillac Owners Enthusiast
    Automobile(s): 2001 GMC SLT, Malibu LTZ, 99 STS studded with NP
    Jul 2010
    Central, NY
    49
    499
    you should be fine
  3. #123
    TINKNOCKER is offline Cadillac Owners Member
    Automobile(s): 1998 Eldorado ETC, 1981 Dodge Crewcab Dually Cowboy Cadillac
    Aug 2011
    Eighty Four, PA
    54
    17
    Hi Faded. Great to see how far in you are! Got my eldo back from the shop with the 72K motor installed and it runs great. Nice clean and tight motor. When this one needs the HG done I'm doing it myself. Have everything necessary except the garage. I was mistaken on the number I gave you on my "twin". 124 with the exact options and 174 with at least as many options. Triple black is sooo sweet. When you have some time, you can check yours out at www.compnine.com for the full RPO code list and rarity of your car with your VIN #. Best of luck with the drilling.
  5. #124
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,180
    The posted RPO tracking website has been dead for about 6 months. There is no plan for its return. The "rarity" of a car found was not correct - that was based on several hidden RPO's in the dealer package order which included the date and lineal number of that particular car - of course it would be one of three that bucked the line at 2:30 - 2:40 on ??? 10/22/02 ???, so, yes - it would be "rare". The old CompNine site acknowledged that fact in the fine print.
  6. #125
    Aug 2011
    Eighty Four, PA
    54
    17
    Didn't mean to provide an outdated link. My last report from compnine was 8/26/2011. Haven't bought anything since. Sub, I lurk all the time without posting, I find you are an incredible font of information.
  7. #126
    tateos's Avatar
    tateos is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 ETC (GAVE TO STEPSON 2011), 2000 DTS (RIP)
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,702
    Marc - I used a circular steel wire wheel on a pneumatic air grinder, albeit a wire wheel that was not too coarse, and already broken in, so no really sharp tips of the wire, on the piston crowns and combustion chamber and valve heads - no damage whatsoever - I could clearly see the factory machining marks on the top of the pistons - a tiny bit of carbon was left in the valve reliefs, which I scraped out with and awl or something similar.
    Richard Moore
  8. #127
    Apr 2008
    North Carolina
    45
    3,183
    Thanks Richard,
    I just finished cleaning them up the other day. I carefully scraped most of the carbon away with a razor and then also used something like an awl to dig out the valve reliefs. I still have yet to clean the vavle heads, so I'll try your method on those. It was a major PITA to scrape everything off the pistons.
  9. #128
    89falcon is offline Cadillac Owners Fanatic
    Automobile(s): my wife crazy, 1997 STS, 2004 CTS
    Apr 2011
    188
    Quote Originally Posted by Faded Crest View Post
    Thanks Richard,
    I've seen people sand and polish piston tops....makes it tougher for carbon to adhere, and theoretically, reduces piton top surface area for less heat (energy) transfer....although I can't imagine that making much difference beyond .00000000001 HP......but the short answer is....clean away!
  10. #129
    Feb 2006
    57,180
    Quote Originally Posted by 89falcon View Post
    Not so
    . Combustion "carbon" (a mixture of fuel additive residue, oil residue [carbon] and snake oil residue) will adhere to a mirror finish piston crown just as well as to a good ol' machine finish piston crown. A polished piston is warm and fuzzy upon assembly, but check it out at 30,000 miles - better yet - at 20,000 city miles.................BUT if you're running an exotic race fuel and methanol, those piston crowns will keep that mirror finish for 400 miles: the next teardown.
  11. #130
    Apr 2008
    North Carolina
    45
    3,183
    Well, I guess I'll put away the jeweler's rouge then.
    basscatt and basscatt like this.
  12. #131
    Apr 2008
    North Carolina
    45
    3,183
    I got the lower case off the block tonight and am concerned at how the lower crankshaft bearings look. Here they are... What do you think?
  13. #132
    Apr 2008
    North Carolina
    45
    3,183
    Do you guys think I need to replace my main bearings?
  14. #133
    Feb 2006
    57,180
    Install new mains and rod bearings. Too much wear and embedded dirt there (pictures). Take a hard look at the crank - maybe polish all the journals with crocus cloth - no regrind recommended. Have you ever used Plastigage to check clearances ? Might be a good idea.
    Read the GM service manual concerning crankshaft and rod bearing reconditioning. You can probably get away with a set of original or maybe .002" under bearings.
    Use a good assembly lube.
  15. #134
    Apr 2008
    North Carolina
    45
    3,183
    Yeah, there's no way I can ignore that. I think sometimes ignorance is bliss.
    I have never used plasti-gage, but I guess it would be a good idea. Do you think I will likely need the same size under rod bearings as main bearings? Should I plasti-gage all of them? Or will a couple of each tell me enough?
    By the way, after I lifted the lower case off, I simply pulled out the old rear main seal. It was very easy to remove, so I was wondering if a new one could be installed the same way since it's apart... or was the old one just shrunken which is why it came out so easily?
  16. #135
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,848
    Yea id replace those bearings, they look nearly shot.
  17. Remove Advertisements
