96 Sedan De Ville V8 Northstar Over Heating
Results 1 to 10 of 10
Like Tree2Likes
  • 4 Post By vincentm
Northstar Engines and System Technical Discussion Discussion, 96 Sedan De Ville V8 Northstar Over Heating in Cadillac Engine Discussion; I Have A 96 Sedan De Ville With A V8 4.6L Northstar Engine And I Bought It From A Friend ...
    VValdez82 is offline Cadillac Owners Member
    Automobile(s): 1995 Sedan De Ville, 1996 Sedan De Ville, 1997 Sedan De Vill
    Mar 2012
    Santa Fe NM
    34
    3
    I Have A 96 Sedan De Ville With A V8 4.6L Northstar Engine And I Bought It From A Friend Knowing The Head Gaskets Needed To Be Replaced, I Just Recently Had The Head Gaskets Replaced & Found Out It Was STILL Over Heating So The Mechanic Replaced The thermostat & The Water Pump And Then Tried Again But It Was Still Over Heating. The Mechanic Flushed The Radiator And The Engine Block A Few Times And Then Serviced All The Coolant Lines. He Says Its Ok Now And That Its Not Over Heating At The Moment But He Said I Should Get Rid Of The Car Because He Said No Mechanics Here In New Mexico Like Working On The Northstar Engines And that The Problem With The Over Heating Is Just Gonna Stay Happening Again & Again If I Decide To Keep The Car. I Really Like The Car And Have Always Wanted A Cadillac But I Dont Know If Everything He Says Is Correct. I Dont Want To Keep Putting Thousands Of Dollars Into The Car If Its Just Gonna Keep having The Same Problem. So i thought I Would Ask Here On What To Do ? Are The Northstar Engines Really That Bad ? Or Will I Be Ok Keeping The Car ?
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,871
    1. Get a new mechanic
    2. What was the fix for the HG, studs or timeserts?
    3. Get a new mechanic
    4. Get a new mechanic
    5. Check if the purge line is clogged
    68
    81,887
    Re: 96 Sedan De Ville V8 Northstar Over Heating
    Did he insert all 20 bolt holes before he replaced the HG? If not, he doesn't know what he is doing, did the job wrong because they failed again and he owes you a refund.
    Mar 2012
    Santa Fe NM
    34
    3
    To tell you the truth im not sure what techniques he did or anyhing. Im just going off what he says. I know he used studs and said he helicoiled or something like that the bolt holes and had a master cadillac mechanic help him but they said its a design flaw being that the engine is aluminum on aluminum its gonna have that over heating problem and that most the time they tell the owners to trash the northstar and get something else. Its very hard to find an honest and reliable mechanic here in new mexico so i dont know. I still havent drove it i just took his word and put a for sale sign on it cause i have to many cars to deal with but that was one ofthe dars i really wanted.
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,998
    Helicoil is an unacceptable method of Northstar bolt hole repair. It won't hold. Properly repaired Northstar doesn't overheat after the repair. The work has been butchered, you need a new mechanic that knows Northstars, and request a refund since the "repair" didn't repair anything.
    Failed helicoil repair picture borrowed from Google/CF
    Faded Crest's Avatar
    Faded Crest is offline Cadillac Owners Connoisseur
    Automobile(s): '66 SDV, '76 CDV, '89 BRM, '92 BRM, '98 Concours, '00 SDV
    Apr 2008
    North Carolina
    45
    3,222
    Quote Originally Posted by maeng9981 View Post
    ...and request a refund since the "repair" didn't repair anything.
    Good luck with that.
    68
    81,887
    Quote Originally Posted by VValdez82 View Post
    Sometimes the term "helicoil" is used generically. You need to find out EXACTLY what he did.
    Mar 2012
    Santa Fe NM
    34
    3
    Ok so the car is worth keeping ? Im just probably gonna have to get the head gaskets replaced again then ? Because i sure as hell aint gonna get a refund i know that for sure
    vincentm's Avatar
    Aug 2010
    Kennewick WA
    38
    4,871
    Why not? Id call them up to report hg failure
    68
    81,887
    That's a decision only you can make.
    It sounds like that may be a possibility based on what you told us, but we can't be sure based on what you told us either. You need to find out exactly what that "mechanic: did and how he did it.
  13. Remove Advertisements
