engine swap for a 2000 dts to a 2003 devell can it work i
Results 1 to 5 of 5
Northstar Engines and System Technical Discussion Discussion, engine swap for a 2000 dts to a 2003 devell can it work i in Cadillac Engine Discussion; i have clean 2000 dts that needs a engine i brought a 2003 deville can it work and what do ...
    science 126 is offline Cadillac Owners Member
    Automobile(s): 2000 DTS AND 2003 DEVELL
    Feb 2012
    3
    i have clean 2000 dts that needs a engine i brought a 2003 deville can it work and what do i need to get to make it work
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,993
    Re: engine swap for a 2000 dts to a 2003 devell can it work i
    00-03 will interchange mechanically, but you cannot swap a VIN 9 (DTS) engine with a VIN Y (Deville) engine right away. The output and the redline is different due to different intake cams and programming. It will start up and drive but you will get unexpected and unknown results.
    To fit a 03 Deville engine into a 00 DTS, you would need to swap the intake cams. What kind of problems are you facing, that lead you to perform an engine swap?
    Feb 2012
    3
    non yet im getting ready to swap the engine out in the 2000 dts for a 2003 deville
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,993
    I meant, if you are having no problems, why are you swapping engines?
    ThumperPup's Avatar
    ThumperPup is offline Cadillac Owners Master
    Automobile(s): not anymore 2007 Lexus ES350
    Mar 2009
    Murray/ Snowbird Utah
    37
    7,688
    i thought it was 00-02 not 00-03
    but perhaps im wrong but could have sworn or maybe thats for a direct swap without electrical changes but also only if the Y is going into a Y or 9 is going into what was a 9
  8. Remove Advertisements
