What causes a headgasket failure?
Results 1 to 6 of 6
Like Tree1Likes
  • 2 Post By Submariner409
Northstar Engines and System Technical Discussion Discussion, What causes a headgasket failure? in Cadillac Engine Discussion; Just curious as to how the headgasket fails on all the Northstars. So far, my 97 ETC with 127,047 miles ...
    97EldETC's Avatar
    97EldETC is offline Cadillac Owners Fanatic
    Automobile(s): 1997 Eldorado ETC
    Dec 2011
    Sunny and Coastal California
    490
    Just curious as to how the headgasket fails on all the Northstars. So far, my 97 ETC with 127,047 miles has run fine since last December 2011 when I purchased her (with a few electrical problems). I'm going to. Change te oil in December (unless I go on a summer road trip of course) and all my fluids are fine. A little shudder happened yesterday in drive, but shifted immediately back to park and back to drive and the shudder tapered off. Other than that. She's fine. Sorry...back to my original question. What causes headgasket failure on the 97-99 northstars?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,139
    Re: What causes a headgasket failure?
    Go up to the stickys at the top of this forum and wade through the headgasket threads. There are several schools of thought - head bolt(s) lose clamping force due to: block thread corrosion from poor casting methods, block thread corrosion caused by coolant intrusion, block thread failure due to fine threads in aluminum; all sorts of scenarios, and none radically different than what has caused head gasket failure in many, many other engines over the years. NO automotive engine is exempt from head gasket failure, regardless of manufacturer, and you can verify that by lurking in any other automotive forum on the internet.
    One possibly preventive ritual is to change the coolant (DEX-COOL or green) religiously every 3 years.
    I was replacing head gaskets on Jaguars, Austin-Healeys, Datsuns and MG's in the late 50's - head gasket failure is not all that uncommon.
    97EldETC's Avatar
    Dec 2011
    490
    I just pray mine won't die on me. It's my first car, so I plan on babying it. Except when I'm on the highway .
    Feb 2006
    57,139
    Drive it like you stole it. The Northstar engine likes to run. My car is 10 years old and just did a run to 126 yesterday: not a problem.
    N*caddy has a '97 STS and did a non-stop circuit of the U.S - almost 11,000 miles - last year with no trouble.
    maeng9981 and maeng9981 like this.
    tateos's Avatar
    tateos is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 ETC (GAVE TO STEPSON 2011), 2000 DTS (RIP)
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,702
    Yes - all of what Sub said - based on my experiences and observations, I favor block thread corrosion caused by coolant intrusion as the most common and most likely explanation. When I did mine, I found totally failed (head bolts didn't catch at all) wet block threads, wet failing block threads, wet, but still good threads (bolts "snapped" when loosened, and threads that were dry and perfectly fine. I think these showed the natural progression, from good to bad, that takes place. I think the reason the threads basically dissolve away is the combination of coolant, steel bolts, an aluminum black, lots of heat and also corrosive combustion gases
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,993
    1. Block thread failure due to reasons stated above
    2. Gasket failure due to failure of corrosion inhibitor in coolant / or lack of maintenance
  9. Remove Advertisements
