Northstar Temp sensor & Lock up converter ?'s
Results 1 to 4 of 4
Northstar Engines and System Technical Discussion Discussion, Northstar Temp sensor & Lock up converter ?'s in Cadillac Engine Discussion; Hello, Looking for some guidance here. I have a 2005 Northstar motor in a kit car and have some questions. ...
    Theo's's Avatar
    Theo's is offline Cadillac Owners Member
    Automobile(s): 2005 Northstar La Bala, Past- 1967 Conv., 1970 Conv.
    Dec 2011
    portage Lakes, Ohio
    41
    12
    Hello, Looking for some guidance here. I have a 2005 Northstar motor in a kit car and have some questions. I need to hook an external temp sensor to the motor, I have an eletric gauge. I believe the the temp snesor on the motor is on the front of the head, correct? There is a yellow and black wire coming from it, Which wire can I splice into to get a temp reading?
    Also, I don't beleieve the converter is locking up, going down the highway at 65MPH I'm taching about 2500RPM. Is there is a way to run a switch to control the lock up in the converter? As I said this is in a kit car, the motor runs great with the excpetion of this. I'm sure there is some error codes and that is the reason the PCM is not signaling it to lock up.
    Any help or thoughts would be greatly apreciated!
    Thank you!
    MacMuse is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS N* 1SE
    Feb 2009
    Chicagoland
    54
    2,399
    This question is more appropriate for the folks that frequent the engine specific area of the site. I'll move the thread over there, but it will also remain visible in STS where you originally posted for a few days.
    Theo's's Avatar
    Dec 2011
    portage Lakes, Ohio
    41
    12
    Re: Northstar Temp sensor & Lock up converter ?'s
    Thank you & sorry about that!
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,857
    The temp sender is on the rear end of the right cylinder head - down under and to the right of the throttlebody. The sensor in the front of the right cylinder head cam cover is the CMP - CaMshaft Position sensor - used to send piston reference signals to the ignition system and injector trigger in the PCM.
    You'll need a 2005 shop manual - GM, not Chilton's or Haynes - to find the transmission/PCM wiring diagrams - as well as figure out the signal voltage to set the TCC; the vehicle speed signal determines TCC lockup (> 43 mph, road loads, < some specific throttle opening %)
  7. Remove Advertisements
