P119 and p080
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, P119 and p080 in Cadillac Engine Discussion; Ok so I have a 1994 Cadillac concours and I've done so much work on this car and this seems ...
    lobato is offline Cadillac Owners Member
    Feb 2012
    1
    P119 and p080
    Ok so I have a 1994 Cadillac concours and I've done so much work on this car and this seems to be my finally hill to get over.
    I'm getting a code p119 which is open or shorted fuel injector as well as p080 which I bbelieve is fuel system to rich
    I have replaces all the fuel injectors as well as the fuel pressure regulator. I can't get to the fuel injectors with a stethoscope because the car will not run with the cover off. I have tried to run the injector test through the dash but I can not physically see the Rome and I really can't feel a difference between them. I also just recently replaced the whole instrument cluster but I did have the issue prior to that.
    Anyone have any suggestions from here??
    I've taken it into two different shops who were unable to solve the issue and I just want my car to run like it should!
    68
    81,917
    Re: P119 and p080
    Actually it will, but you DO NOT want to do it as it will runaway at WOT. Since the injectors have been replaced I'd look at the wiring up line.
    94CaddyConcours's Avatar
    94CaddyConcours is offline Cadillac Owners Fanatic
    Automobile(s): 1994 CADILLAC DEVILLE CONCOURS, 350ZR
    Jul 2004
    LONG BEACH KALIFORNIA, HOUSTON
    444
    I have P119 before. The insulation for one of the injector became brittle and crack whick causes the injector to run/spray continiously. My fuel economy was around 13mpg. Since you replaced all the injector the only thing I can think of is the wire insulation. Pull the intake cover and check the wire.
    Also what was the reason you replaced the cluster? Mine would go on and off. My theory is that when I have the heater on it warm the cluster and somehow it would go blank.
    I also had P080 when I swithced from premium fuel to regular. It should adjust itself after it is used to regular.
