4.6 Rod Clearance
Results 1 to 7 of 7
Northstar Engines and System Technical Discussion Discussion, 4.6 Rod Clearance in Cadillac Engine Discussion; I am building a new 4.6 northstar to use in my class 1 offroad racecar. I am mocking up my ...
    sqrly1776 is offline Cadillac Owners Member
    Automobile(s): NorthStar powered class 1 offroad racecar
    Feb 2012
    33
    4.6 Rod Clearance
    I am building a new 4.6 northstar to use in my class 1 offroad racecar. I am mocking up my crank with rods. I am looking for the rod clearances as i am starting with new eagle forged rods.
    I was told to measure clearance between the two rods when installed on the crank.
    What should this clearance be?
    ternstes is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS V, 2007 SRX V8, 2005 CTS 3.6L, 2000 STS, 1999 STS
    Nov 2008
    SW Ohio
    36
    394
    Re: 4.6 Rod Clearance
    Here is the procedure for a 2000 year
    Note the orientation of paired connecting rods on each crankpin. The notches in the connecting rod cap must be facing each other.
    Before removing the connecting rods, check the connecting rod end play using the following procedure:
    2.1. Tap the connecting rod to one end of the crankshaft journal with a dead-blow or wooden hammer.
    2.2. Using feeler gages, measure the clearance between the crankshaft counterweight and the connecting rod.
    2.3. The connecting rod end play should not exceed 0.500 mm (0.020 in).
    2.4. If the end play exceeds the specified limits, measure the width of the crankpin end of the connecting rod.
    2.5. The width of the crankpin end of the connecting rod should be 21.745 - 21.805 mm (0.856 - 0.858 in).
    2.6. If the connecting rod width is significantly smaller than specified and severe wear is present on the side of the connecting rod, replace the connecting rod.
    2.7. If the connecting rod width is within specification and excessive scoring is present on the crankshaft journals, replace the crankshaft.
    Submariner409's Avatar
    Submariner409 is online now If it won't run, stick on fender vents
    Feb 2006
    MD Eastern Shore, Kent Island
    56,603
    2002 gives .008" to .020" total side clearance.
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,263
    If you have one rod or one journal out of spec, check for a bent connecting rod.
    Don't mess with Binky Bear!
    Speedygman is offline Cadillac Owners Fanatic
    Automobile(s): NorthStar 32 Vicky/ 58 CHEVY BROOKWOOD 348, 1983 Manta RX7
    Mar 2011
    Juliette Ga.
    74
    170
    I would contact the rod manufacturer and see what side clearance they recommend.
    Mark D is offline Cadillac Owners Member
    Automobile(s): 1995 Seville STS 1998 Seville STS 1995 Seville SLS 2000 ET
    Nov 2011
    Minnesota
    42
    I'd like to read more about this little project. It has caught my interest.
    Mark D.
    Feb 2006
    56,603
    For ideas on kit cars, hot rod, and sand rail Northstars, check out the CHRFAB website and search posts in CF by speedygman.
  10. Remove Advertisements
