Help...Service Engine Light
Results 1 to 7 of 7
Northstar Engines and System Technical Discussion Discussion, Help...Service Engine Light in Cadillac Engine Discussion; The service engine light came on about a week ago on my 98 Deville. I checked the codes....got at PO442. ...
    mbokishet is offline Cadillac Owners Member
    Mar 2004
    11
    The service engine light came on about a week ago on my 98 Deville. I checked the codes....got at PO442. Have no idea what that means. Today after getting gas, I tried to start the car and starting was diabled. Waited for the 3 minutes and she started. Checked codes when I got home. Still have PO442, now I also have PO463. What are these codes and what is the fix for their problems. I would greatly appreciate any help I can get. I am beating head off wall, cause eveytime I turn around there is something wrong with this car.
    Sep 2003
    Metro ATL
    4,854
    Re: Help...Service Engine Light
    P0442 = Evaporative Emission (EVAP) System Small Leak Detected. Could be as simple as gas cap not properly installed, or a defective gas cap.
    P0463 = Fuel Level Sensor Circuit High Voltage. Several possibilities here.
    Clear the codes and see if they return.
    Mar 2004
    11
    Thanks Jim.......will get new gas cap today and try it. Would be great if for once it was an inexpensive repair.
    Mar 2004
    11
    Back to square one guys. Gas cap worked for about two weeks. Now having really strange problem. Light came on again. If you fill the car with gas and reset computer the light stays off. As soon as the gas gauge reads seven gallons the light comes back on. Fill'er up again reset computer....ok till 7 gallons. I am really stumped. Can you help? Thanks!
    69
    82,266
    What codes are you getting now? Maybe you fixed the P0442 with the gas cap but the fuel level sensor is bad. Sounds like you had two seperate issues.
    Mar 2004
    11
    Still getting a PO442 code......even with new gas cap......I am confused.
    69
    82,266
    Check all the vacuum hoses on the evap solenoid. It is mounted on the rear cam cover (driver side) if memory serves me correctly.
  10. Remove Advertisements
