Determining Headbolt Thread Pitch - Page 2
Results 16 to 30 of 38
Like Tree2Likes
Northstar Engines and System Technical Discussion Discussion, Determining Headbolt Thread Pitch in Cadillac Engine Discussion; Thanks Chris and Ranger..I have seen the light now..That link was very informative.....
  1. #16
    postman2000's Avatar
    postman2000 is offline Cadillac Owners Fanatic
    Automobile(s): 1996 STS 2000 Deville
    May 2009
    293
    Re: 2004 Deville Determining Headbolt Thread Pitch
  2. #17
    SGWORLDWIDE Guest
    OMG i feel so relieved now great info i just came across the thread and just went out side at 4AM to check the label and my 04 DTS is a JKA knew she was a winner day i got her steal for $5000 grand guy took $1000 off for a cracked grill and broken rear regulator i forgot to look at when she was built but im happy now since im fixing all the little things little by little last thing i wanted to know was it kinda be for noting considering the earlier northstars are bound to go sooner or later thanks guys
  3. #18
    00 Deville's Avatar
    00 Deville is offline Cadillac Owners Connoisseur
    Automobile(s): 02 Deville / 04 Deville
    Mar 2004
    Wilmington, NC
    51
    2,659
    Quote Originally Posted by SGWORLDWIDE View Post
    Glad to hear that you where able to determine you have the improved 2mm thread pitch.
    What's your engine build date? It's the date at the bottom of the sticker as pictured below.
  5. #19
    SGWORLDWIDE Guest
    Build date is 8/8/03 mmmh 03 should i be concerned? it says JKA and there werent no earlier JKA's built on the list what u guys think do i got the 2mm's?
  6. #20
    00 Deville's Avatar
    Mar 2004
    Wilmington, NC
    51
    2,659
    Very interesting...
    That's an early build date on an L37 (04 DTS) engine. It must be a very small number of 04 DTS's that came with the smaller 1.5mm threads. According to the parts catalog you have the larger 2mm threads.
  7. #21
    SGWORLDWIDE Guest
    Hey guys HAPPY NEW YEAR anyway figured i reopen this thread okay so now we have some proof on the deville engine ID's about what thread pitch they have but what about the sevilles? 98 to 04 SLS or 98 to 03 for STS model? pre 04 has the 1.5 threads but what about a 04 SLS? and a 03 STS is also possable i think as i have a 04 DTS with a L37 built in august 03 with ID number JKA which indicates the 2.0 threads?
  8. #22
    Biggus Blockus is offline Cadillac Owners Member
    Automobile(s): none
    Mar 2009
    50
    Great question! Anyone know if the 2004 SLS has the same engine codes?
  9. #23
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    Same info applies to the 2004 Sevilles here as it applies to the 2004 Devilles
    check the engine ID to see which group you fall into
  10. #24
    JackOverIP is offline Cadillac Owners Member
    Automobile(s): 1997 Deville
    May 2013
    1
    Do these engine IDs apply to the 2006 DTS also? I understand the statements that assign L37/LD8 to 2004's but would like to be absolutely certain before I buy this 2006 DTS. Just finished a $2500 time-sert head gasket job on my 97 deville Northstar.
  11. #25
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    All '05+ Northstars have the larger bolts.
  12. #26
    ryannel2003's Avatar
    ryannel2003 is offline Cadillac Owners Connoisseur
    Automobile(s): 2001 Honda Accord EX V6. Previous: 2004 Deville, 2000 STS
    Apr 2007
    New Bern, NC
    26
    3,718
    This is very useful information here. The STS I looked at had blown HG's and I'm now pursuing an '04 Deville Base and this has me very relieved that the car could have the longer head bolts.
  13. #27
    zentrade is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac 1993 Deville 4.9, 1991 Eldorado Touring Coupe
    Dec 2006
    370
    Ok so i am looking at a 2004 SLS. Build date is 6/27/03 for the engine. It has JMA as the part code. But does the engine have to have been built in `04?
  14. #28
    Submariner409's Avatar
    Submariner409 is offline If it won't run, stick on fender vents
    Feb 2006
    MD Eastern Shore, Kent Island
    55,590
    The 2004 model year ran from about late July 2003 to early June 2004. The engine could have been built at any time before or during that run - the engine build and ID number is on the end of the right (rear) cam cover. Many of the parts for your car's body were probably stamped out in earlier 2003 - for a "2004" car. Same for the engine parts and even the carpets.
    The final build date (within 30 days) for the car is on the driver's door sticker.
    Changes - in every part of the car - are (computer programmed and) made on the fly. A car built on 08/30/03 might have an entirely different widget control sensor from one that rolled off the line on 09/01/03........... and maybe different for one that was built in 05/2004 - toward the end of the 2004 year.
  15. #29
    Dec 2006
    370
    Thanks! Yes i was aware that although parts for any given model year could have been made at any time including the previous year(s) for that model year. I was under the belief that the engines made specifically after a certain date in 04 have the upgrade. So, not only for the model year 04 but also manufactured in 04 as well.
  16. #30
    Dec 2006
    370
    I guess what i am actually asking is : For all model year Northstars were the head bolts updated...or just for engines manufactured in year 2004?
  17. Remove Advertisements
