Do The 2006 and newer DTS Northstars have the same headgasket issues?
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 19
Northstar Engines and System Technical Discussion Discussion, Do The 2006 and newer DTS Northstars have the same headgasket issues? in Cadillac Engine Discussion; My engine block in my 2000 has had a crack now for 3 years..This year it seems to be getting ...
    postman2000's Avatar
    postman2000 is offline Cadillac Owners Fanatic
    Automobile(s): 1996 STS 2000 Deville
    May 2009
    296
    My engine block in my 2000 has had a crack now for 3 years..This year it seems to be getting worse..Have to add more and more antifreeze..Im debating whether to fix this engine or just get another car..My question is this..Do the 2006 and newer DTS's have any issues with the head gaskets or head bolts...or any other common failures that I should be aware of?
    68
    81,928
    Re: Do The 2006 and newer DTS Northstars have the same headgasket issues?
    Not that I have heard of. Seems like there have been very few since the thread pitch change in '04.
    May 2009
    296
    So in theory if i found a really clean 2005 i should'nt have to worry too much about the head bolts pulling? I personally like the 2000 - 2005 style better than the 2006 and newer..Thanks Ranger..
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,998
    Yes - just replace the coolant regularly and you wouldn't deal with the gasket/bolts problem anymore.
    JoeTahoe is offline Cadillac Owners Enthusiast
    Automobile(s): 2001 GMC SLT, Malibu LTZ, 99 STS studded with NP
    Jul 2010
    Central, NY
    48
    502
    I have a friend that bought a 2005 deville and it did have a pulled head bolt now it has jakes studs in it. Had around 130000 on it. It is also a auction car. This was this last spring. But it is the only one I have ever seen or herd of so far
    May 2009
    296
    Wow a 2005 with a head bolt problem..That sucks..I dont know what to think now..
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,872
    Quote Originally Posted by postman2000 View Post
    Could've been due to poor maintenace, don't get paranoid
    00 Deville's Avatar
    00 Deville is offline Cadillac Owners Connoisseur
    Automobile(s): 02 Deville / 04 Deville
    Mar 2004
    Wilmington, NC
    52
    2,659
    So in theory if i found a really clean 2005 i should'nt have to worry too much about the head bolts pulling? I personally like the 2000 - 2005 style better than the 2006 and newer...
    You should be able to extend your search to include the 04 model year now that we are able to determine which 04's have the same head bolts as an 05.
    http://www.cadillacforums.com/forums...ead-pitch.html
    bigtone's Avatar
    bigtone is offline Cadillac Owners Enthusiast
    Automobile(s): 2010 DTS, 2006 DTS, 2001 Deville,
    Jun 2003
    545
    While researching inserts for my son's 2001 Deville with a failed H/G, I was told that there has been some demand for 2004 and 2005's. Not good news.
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    ... we have not seen many pulled head bolts on the 2004.5/2005+ redesigned bolts ((one or two maybe)
    there have also been a handful of true headgasket failures ... in these cases we have not studded the block and have not had any problems with those cars since
    (seems like a very low headgasket failure rate to me...)
    bigtone's Avatar
    Jun 2003
    545
    That is very good to hear.
    May 2009
    296
    Hey Chris, Do you know of any headgasket or head bolt problems on any 2006 or newer DTS that have come into your dealership? Also do the 06 and newer DTS have any other major problems of their own that you are aware of? I thank you for your time...
    Sep 2007
    Wilmington, NC
    13,986
    We've seen a few gasket failures but no bolt failures
    as I said earlier, we've seen a couple bolt failures on 2005's (which should have the same bolt design as the 2006+)
    well they're not bolt failures like the previous designs where they would pull out
    these are loose bolts (which probably has to do with the gasket failures)
    i'm not sure if they're backing out or if they were always loose and it was a factory build problem
    but it's not really that many - I just checked the sales history and we've done 5 in the last 24 months
    besides lower block seal leaks (which are also greatly reduced with the new N* design) i can't really think of anything else that is common at all
  16. #14
    00 Deville's Avatar
    Mar 2004
    Wilmington, NC
    52
    2,659
    So the 5 sales in the last 24 months would be on the head gasket kit # 89017600 that is used on the following cars...
    - 04-05 Deville
    - 06-11 DTS
    For comparison could you share 24 month usage on head gasket kit # 12564795 that is used on the 00-04 N*.
  17. #15
    Sep 2007
    Wilmington, NC
    13,986
    yeah, i thought to do that yesterday but was a bit rushed
    12560633/12560632 - 19 repairs in 24 months (1993-1999 N*)
    12564795/12564796 - 26 repairs in 24 months (2000-2004 N*)
  18. Remove Advertisements
