1994 Deville Concours Ignition Control Module Replacement
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, 1994 Deville Concours Ignition Control Module Replacement in Cadillac Engine Discussion; Hello all, I have a question..I remember a mechanic told me that on the old school GM HEI ignitions that ...
    postman2000's Avatar
    postman2000 is offline Cadillac Owners Fanatic
    Automobile(s): 1996 STS 2000 Deville
    May 2009
    292
    Hello all, I have a question..I remember a mechanic told me that on the old school GM HEI ignitions that when you replaced the ignition module you were supposed to put some dielectric grease on the bottom so the module would not get too hot. Is that something I should do on the module for the 94 Northstar? If i choose to do it will it hurt anything? Thanks for your input and opinions..
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,816
    Re: 1994 Deville Concours Ignition Control Module Replacement
    Not dielectric grease - IC ("chip") heat sink grease. Radio Shack. White, pasty stuff - transfers heat from the IC/chip/diode/regulator/output transistor(s) to the mounting base/heat sink.
    The early Northstar ICM is a stand-alone module which mounts the coils. No transfer grease needed.
    May 2009
    292
    Thanks alot Sub! Yes thats the stuff I was talking about..I mistakenly referred to it as Dielectric grease..Thanks again..
